path: root/c/src/tests/libtests/monitor/Makefile.in (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Added Monitor test.Joel Sherrill1997-09-211-0/+60
