* cpuuse/.cvsignore: Remove.
* cpuuse/Makefile.am: Remove.
* cpuuse/cpuuse.scn: Remove.
* cpuuse/init.c: Remove.
* cpuuse/system.h: Remove.
* cpuuse/task1.c: Remove.
* cpuuse/task2.c: Remove.
* cpuuse/task3.c: Remove.
* cpuuse/tswitch.c: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* libtests.am: Remove.
* malloctest/.cvsignore: Remove.
* malloctest/Makefile.am: Remove.
* malloctest/init.c: Remove.
* malloctest/malloctest.scn: Remove.
* malloctest/system.h: Remove.
* malloctest/task1.c: Remove.
* monitor/.cvsignore: Remove.
* monitor/Makefile.am: Remove.
* monitor/init.c: Remove.
* monitor/system.h: Remove.
* putenvtest/.cvsignore: Remove.
* putenvtest/Makefile.am: Remove.
* putenvtest/init.c: Remove.
* rtems++/.cvsignore: Remove.
* rtems++/Init.cc: Remove.
* rtems++/Makefile.am: Remove.
* rtems++/System.h: Remove.
* rtems++/Task1.cc: Remove.
* rtems++/Task2.cc: Remove.
* rtems++/Task3.cc: Remove.
* rtems++/rtems++.doc: Remove.
* rtems++/rtems++.scn: Remove.
* rtmonuse/.cvsignore: Remove.
* rtmonuse/Makefile.am: Remove.
* rtmonuse/getall.c: Remove.
* rtmonuse/init.c: Remove.
* rtmonuse/rtmonuse.scn: Remove.
* rtmonuse/system.h: Remove.
* rtmonuse/task1.c: Remove.
* stackchk/.cvsignore: Remove.
* stackchk/Makefile.am: Remove.
* stackchk/blow.c: Remove.
* stackchk/init.c: Remove.
* stackchk/stackchk.scn: Remove.
* stackchk/system.h: Remove.
* stackchk/task1.c: Remove.
* termios/.cvsignore: Remove.
* termios/Makefile.am: Remove.
* termios/README: Remove.
* termios/init.c: Remove.
* cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c,
cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c,
malloctest/system.h, malloctest/task1.c, monitor/init.c,
monitor/system.h, putenvtest/init.c, rtems++/Init.cc,
rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c,
stackchk/blow.c, stackchk/init.c, stackchk/system.h,
stackchk/task1.c: URL for license changed.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
* malloctest/init.c: Tasks should be floating point.
* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c,
rtmonuse/task1.c, termios/init.c: Modified.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and now must
be referenced as <rtems/XXX.h>.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
I have a few patches for the efi332 bsp. If you let me know when you
expect the next snapshot release, I will try to have them to you
before then. Also, the malloctest has some problems that I would think
would prevent it from running on almost any platform. I have enclose
patches below to fix (1) Task_id and Task_name dimensioning, (2) end
of test message, (3) the amount of memory malloc'ed, and (4) retry on
unsuccessful (out of memory) molloc's.
more accurate.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
(ostertag@transition.com)
