* cpuuse/.cvsignore: Remove.
* cpuuse/Makefile.am: Remove.
* cpuuse/cpuuse.scn: Remove.
* cpuuse/init.c: Remove.
* cpuuse/system.h: Remove.
* cpuuse/task1.c: Remove.
* cpuuse/task2.c: Remove.
* cpuuse/task3.c: Remove.
* cpuuse/tswitch.c: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* libtests.am: Remove.
* malloctest/.cvsignore: Remove.
* malloctest/Makefile.am: Remove.
* malloctest/init.c: Remove.
* malloctest/malloctest.scn: Remove.
* malloctest/system.h: Remove.
* malloctest/task1.c: Remove.
* monitor/.cvsignore: Remove.
* monitor/Makefile.am: Remove.
* monitor/init.c: Remove.
* monitor/system.h: Remove.
* putenvtest/.cvsignore: Remove.
* putenvtest/Makefile.am: Remove.
* putenvtest/init.c: Remove.
* rtems++/.cvsignore: Remove.
* rtems++/Init.cc: Remove.
* rtems++/Makefile.am: Remove.
* rtems++/System.h: Remove.
* rtems++/Task1.cc: Remove.
* rtems++/Task2.cc: Remove.
* rtems++/Task3.cc: Remove.
* rtems++/rtems++.doc: Remove.
* rtems++/rtems++.scn: Remove.
* rtmonuse/.cvsignore: Remove.
* rtmonuse/Makefile.am: Remove.
* rtmonuse/getall.c: Remove.
* rtmonuse/init.c: Remove.
* rtmonuse/rtmonuse.scn: Remove.
* rtmonuse/system.h: Remove.
* rtmonuse/task1.c: Remove.
* stackchk/.cvsignore: Remove.
* stackchk/Makefile.am: Remove.
* stackchk/blow.c: Remove.
* stackchk/init.c: Remove.
* stackchk/stackchk.scn: Remove.
* stackchk/system.h: Remove.
* stackchk/task1.c: Remove.
* termios/.cvsignore: Remove.
* termios/Makefile.am: Remove.
* termios/README: Remove.
* termios/init.c: Remove.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
