path: root/c/src/tests/libtests/libtests.am (unfollow)
2001-09-242001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile: Remove LD_LIBS.
2000-10-272000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * libtests.am: Remove DEFS.
2000-07-13Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+2
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
1999-11-23Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+11
