path: root/c/src/tests/itrontests/Makefile.am (unfollow)
1999-11-10General cleanup. Test documentation improved. The message buffer testJoel Sherrill1-2/+1
prints a message instead of actually testing since the message buffer implementation is not in yet.
1999-11-10Combination of committing some new files which had been overlookedJoel Sherrill1-1/+1
and adding code which installed screens for itron tests.
1999-11-09Added more tasking tests.Joel Sherrill1-1/+2
1999-11-09This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1-5/+2
for RTEMS.
1999-11-09New test for POSIX Message Queues added.Joel Sherrill1-1/+1
1999-10-28New test added - psxcancel. This is just a shell for now.Joel Sherrill1-1/+1
1999-10-04Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1-3/+3
1999-08-10New configuration files added by patch fromJoel Sherrill1-0/+24
