* lib/libcpu/shared/include/cache.h,
lib/libcpu/shared/src/cache_aligned_malloc.c,
lib/libcpu/shared/src/cache_manager.c, support/version.c: URL for
license changed.
* support/version.c: Reflect having remove "rtems-" from
RTEMS_VERSION.
