* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
it work.
MP_packet_Classes
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
