path: root/c/src/optman (follow)
* 2003-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-032-13/+6
| | | | | | PR 338/filesystem * sapi/no-io.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). Unused function removed.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-122-2/+11
| | | | * Makefile.am: Apply install-data-local to install *.rels.
* 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-112-6/+8
| | | | | * Makefile.am: Eliminate *_O_FILES. Don't create $ARCH in %.o: %.c rules.
* 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-112-2/+6
| | | | * Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-102-7/+11
| | | | * Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
* 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-072-1/+4
| | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-062-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE.
* 2002-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-206-58/+52
| | | | | | | | | * Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am. * sapi/Makefile.am: Removed. * rtems/Makefile.am: Removed. * rel.am: Removed. * configure.ac: Add RTEMS_BSP_CHECK_CACHE. Reflect changes above.
* 2002-11-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-084-38/+30
| | | | | | * rtems/Makefile.am: Reworked. * sapi/Makefile.am: Reworked. * rel.am: New.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-1/+7
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-092-0/+5
| | | | * .cvsignore: Add autom4te.cache.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-113-2/+7
| | | | | * rtems/Makefile.am: Use .$(OBJEXT) instead of .o. * sapi/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-233-3/+10
| | | | | | * sapi/Makefile.am: Add bsplib_DATA = $(PGMS). Remove ASM4FLAGS. * rtems/Makefile.am: Add bsplib_DATA = $(PGMS).
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-9/+7
| | | | | | | * configure.ac: Remove RTEMS_ENABLE_MULTIPROCESSING, RTEMS_ENABLE_POSIX, RTEMS_ENABLE_ITRON, RTEMS_ENABLE_INLINES, RTEMS_ENABLE_RTEMS_DEBUG, RTEMS_CHECK_RTEMS_DEBUG, RTEMS_CHECK_NEWLIB.
* 2002-06-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-154-5/+7
| | | | | | * Makefile.am: Remove multilib support. * configure.ac: Ditto. * sapi/Makefile.am: Ditto.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-162-1/+4
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-062-0/+6
| | | | * .cvsignore: Added aclocal.m4 and configure.
| | | | * .cvsignore: New file.
* 2002-01-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-046-1/+67
| | | | | | | | * ChangeLog: New. * configure.ac: New. * Makefile.am: New. * rtems/*: Copied from c/src/exec/rtems/optman. * sapi/*: Copied from c/src/exec/sapi/optman.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-191-3/+3
| | | | | * src/Makefile.am: Add multilib support. * optman/Makefile.am: Add multilib support.
| | | | | * optman/Makefile.am: Add multilib support. * src/Makefile.am: Add multilib support.
* 2001-10-16 Chris Johns <ccj@acm.org>Joel Sherrill2001-10-161-0/+27
| | | | | | | | * include/confdefs.h, include/rtems/config.h, include/rtems/io.h, optman/no-io.c, src/exinit.c, src/io.c: Added a device driver register/unregister interface to allow device drivers to be installed and removed at runtime. This means you do not need devices present in the device table when you build.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-2/+3
| | | | * optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-2/+0
| | | | | | | * include/Makefile.am, include/rtems/rtems/Makefile.am, inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am, rtems/optman/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
| | | | * optman/Makefile.am, src/Makefile.am: Include compile.am.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-4/+3
* Patch rtems-rc-19991203-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-212-17/+11
| | | | | | | | | | | which fixes a nasty dependency bug in optman/Makefile.am. Those directories have been build twice before, i.e. re-running make after having built rtems before, was rebuilding the files in optman/ directories. To apply: patch -p1 < rtems-rc-19991203-6.diff ./bootstrap
* Patch rtems-rc-19991123-rc-3.diff from Ralf CorsepiusJoel Sherrill1999-12-031-5/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de>: The patch below provides * automake support for score/cpu/powerpc * The hack to propagate values from *.cfg to automake configuration * A fix for librdbg/powerpc/mcp750/Makefile.am (Was completely corrupted before) * Fixes some files which apparently where missing in rtems-rc-19991123-rc-2.diff * some minor configuration related patches To apply: rm -rf ./c/src/exec/score/cpu/powerpc/wrap patch -p1 < rtems-rc-19991123-rc-3.diff Attention: c/src/exec/score/cpu/[configure.in|aclocal.m4|configure] should be removed after applying the patch. Modifications had been made to the score/cpu/powerpc directory after the snapshot this was based on. In particular, the mpc750 and other_cpu directories had been renamed to new_exception_processing and old_exception_processing. After this patch was applied, modifications were made to account for this.
* Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-232-2/+2
| | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files
* Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-232-0/+79
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Updated copyright notice.Joel Sherrill1999-11-1712-24/+12
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-1/+4
| | | | it work.
* updated copyright to 1998Joel Sherrill1998-02-1712-12/+12
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0812-24/+24
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2212-60/+60
* removed include of unnecessary include file.Joel Sherrill1997-01-281-1/+0
* _MPCI_Register_packet_processor: changed protoype first parameter type to ↵Mark Johannes1996-08-081-1/+1
| | | | MP_packet_Classes
* modified to generate fatal error when an unconfigured directive is invoked.Joel Sherrill1996-04-1912-4/+397
* update to reflect internal threads reorganizationJoel Sherrill1996-03-211-0/+22
* Changed io manager initialization routine to not be static.Joel Sherrill1996-02-211-0/+8
* MPCI Receive became a thread and the prototype changed.Joel Sherrill1996-02-211-1/+3
* posix support initially addedJoel Sherrill1995-09-2612-47/+47
* More file movementJoel Sherrill1995-09-215-6/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1112-150/+184
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-282-6/+7
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-238-16/+16
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-172-32/+38
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Split out event manager support functionJoel Sherrill1995-08-041-20/+0
