* Makefile.am: Add dependencies to $(ARCH)/$(dirstamp).
Reformat.
* Makefile.am: Remove all-local: $(ARCH).
* rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c,
rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c,
rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL
for license changed.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
Reflect having merged configure.ac into ../configure.ac
PR 338/filesystem
* sapi/no-io.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change). Unused function removed.
* Makefile.am: Apply install-data-local to install *.rels.
* Makefile.am: Eliminate *_O_FILES.
Don't create $ARCH in %.o: %.c rules.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am.
* sapi/Makefile.am: Removed.
* rtems/Makefile.am: Removed.
* rel.am: Removed.
* configure.ac: Add RTEMS_BSP_CHECK_CACHE.
Reflect changes above.
* rtems/Makefile.am: Reworked.
* sapi/Makefile.am: Reworked.
* rel.am: New.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* rtems/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Add bsplib_DATA = $(PGMS).
Remove ASM4FLAGS.
* rtems/Makefile.am: Add bsplib_DATA = $(PGMS).
* configure.ac: Remove RTEMS_ENABLE_MULTIPROCESSING,
RTEMS_ENABLE_POSIX, RTEMS_ENABLE_ITRON, RTEMS_ENABLE_INLINES,
RTEMS_ENABLE_RTEMS_DEBUG, RTEMS_CHECK_RTEMS_DEBUG,
RTEMS_CHECK_NEWLIB.
* Makefile.am: Remove multilib support.
* configure.ac: Ditto.
* sapi/Makefile.am: Ditto.
* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* .cvsignore: Added aclocal.m4 and configure.
* .cvsignore: New file.
* ChangeLog: New.
* configure.ac: New.
* Makefile.am: New.
* rtems/*: Copied from c/src/exec/rtems/optman.
* sapi/*: Copied from c/src/exec/sapi/optman.
* src/Makefile.am: Add multilib support.
* optman/Makefile.am: Add multilib support.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* optman/Makefile.am, src/Makefile.am: Include compile.am.
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
it work.
MP_packet_Classes
