* optman/rtems/no-sem.c: Semaphores are rtems_id not Object_id.
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am
support/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* optman/Makefile.am: Set EXEEXT = <empty> (Work around to a bug in
automake).
* optman/rtems/no-region.c: Reflect having changed
rtems_region_get_segment_size.
* optman/rtems/no-dpmem.c, optman/rtems/no-mp.c,
optman/rtems/no-msg.c, optman/rtems/no-part.c,
optman/rtems/no-region.c, optman/rtems/no-rtmon.c,
optman/rtems/no-sem.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert to using c99
fixed size types.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* ChangeLog: Merge-in optman/ChangeLog.
* optman/ChangeLog: Remove.
* Makefile.am: Use automake compilation rules.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Remove project_libdir.
* Makefile.am: Add tmpinstall dirstamp support.
* Makefile.am: Add dependencies to $(ARCH)/$(dirstamp).
Reformat.
* Makefile.am: Remove all-local: $(ARCH).
* rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c,
rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c,
rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL
for license changed.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am:
Reflect having merged configure.ac into ../configure.ac
PR 338/filesystem
* sapi/no-io.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change). Unused function removed.
* Makefile.am: Apply install-data-local to install *.rels.
* Makefile.am: Eliminate *_O_FILES.
Don't create $ARCH in %.o: %.c rules.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am.
* sapi/Makefile.am: Removed.
* rtems/Makefile.am: Removed.
* rel.am: Removed.
* configure.ac: Add RTEMS_BSP_CHECK_CACHE.
Reflect changes above.
* rtems/Makefile.am: Reworked.
* sapi/Makefile.am: Reworked.
* rel.am: New.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* rtems/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Add bsplib_DATA = $(PGMS).
Remove ASM4FLAGS.
* rtems/Makefile.am: Add bsplib_DATA = $(PGMS).
* configure.ac: Remove RTEMS_ENABLE_MULTIPROCESSING,
RTEMS_ENABLE_POSIX, RTEMS_ENABLE_ITRON, RTEMS_ENABLE_INLINES,
RTEMS_ENABLE_RTEMS_DEBUG, RTEMS_CHECK_RTEMS_DEBUG,
RTEMS_CHECK_NEWLIB.
* Makefile.am: Remove multilib support.
* configure.ac: Ditto.
* sapi/Makefile.am: Ditto.
* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* .cvsignore: Added aclocal.m4 and configure.
* .cvsignore: New file.
* ChangeLog: New.
* configure.ac: New.
* Makefile.am: New.
* rtems/*: Copied from c/src/exec/rtems/optman.
* sapi/*: Copied from c/src/exec/sapi/optman.
