* | Use size_t for sizes. | Ralf Corsepius | 2007-02-06 | 1 | -6/+6 |
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | 2006-12-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-12-13 | 1 | -3/+0 |
| | | | | | PR 1181/bsps * optman/rtems/no-msg.c: Clean up dead code. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+8 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 1 | -3/+3 |
| | | | | | * optman/sapi/no-io.c: Change rtems_io_register_name to take a const char *. | ||||
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -51/+3 |
| | | | | * optman/Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2005-08-15 | 1 | -0/+58 |
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -6/+6 |
| | | | | * optman/rtems/no-sem.c: Semaphores are rtems_id not Object_id. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 1 | -12/+12 |
| | | | | | | | | * libchip/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -165/+50 |
| | | | | | | * libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am support/Makefile.am, wrapup/Makefile.am: Remove build-variant support. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-09 | 1 | -0/+2 |
| | | | | | * optman/Makefile.am: Set EXEEXT = <empty> (Work around to a bug in automake). | ||||
* | 2004-04-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-02 | 1 | -1/+1 |
| | | | | | * optman/rtems/no-region.c: Reflect having changed rtems_region_get_segment_size. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 10 | -41/+41 |
| | | | | | | | | | * optman/rtems/no-dpmem.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c, optman/rtems/no-part.c, optman/rtems/no-region.c, optman/rtems/no-rtmon.c, optman/rtems/no-sem.c, optman/rtems/no-timer.c, optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert to using c99 fixed size types. | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 1 | -2/+1 |
| | | | | | | * libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am, wrapup/Makefile.am: Fix automake problems having been introduced in previous patch. | ||||
* | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 1 | -1/+2 |
| | | | | | | | | | * libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am: Preinstall dirs. * wrapup/Makefile.am: Preinstall dirs. Cosmetics. * aclocal/check-multiprocessing.m4: Cosmetics. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX. | ||||
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 1 | -1/+0 |
| | | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am, support/Makefile.am: Don't include lib.am. | ||||
* | 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-23 | 1 | -148/+0 |
| | | | | | * ChangeLog: Merge-in optman/ChangeLog. * optman/ChangeLog: Remove. | ||||
* | Cleanup ChangeLog. | Ralf Corsepius | 2004-01-23 | 1 | -35/+12 |
* | remove bogus ChangeLog entry | Ralf Corsepius | 2004-01-21 | 1 | -3/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 1 | -0/+3 |
* | 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-15 | 2 | -47/+190 |
| | | | | * Makefile.am: Use automake compilation rules. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+10 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-13 | 2 | -39/+43 |
| | | | | * Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -0/+8 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -1/+4 |
| | | | | * Makefile.am: Remove project_libdir. | ||||
* | 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-09 | 2 | -16/+64 |
| | | | | * Makefile.am: Add tmpinstall dirstamp support. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 2 | -5/+10 |
| | | | | | * Makefile.am: Add dependencies to $(ARCH)/$(dirstamp). Reformat. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 13 | -12/+19 |
| | | | | | | | * rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c, rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c, rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL for license changed. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -3/+7 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-07-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-07-10 | 3 | -32/+9 |
| | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-03 | 2 | -13/+6 |
| | | | | | | PR 338/filesystem * sapi/no-io.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). Unused function removed. | ||||
* | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-12 | 2 | -2/+11 |
| | | | | * Makefile.am: Apply install-data-local to install *.rels. | ||||
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 2 | -6/+8 |
| | | | | | * Makefile.am: Eliminate *_O_FILES. Don't create $ARCH in %.o: %.c rules. | ||||
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 2 | -2/+6 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-10 | 2 | -7/+11 |
| | | | | * Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES. | ||||
* | 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-07 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg. | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-20 | 6 | -58/+52 |
| | | | | | | | | | * Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am. * sapi/Makefile.am: Removed. * rtems/Makefile.am: Removed. * rel.am: Removed. * configure.ac: Add RTEMS_BSP_CHECK_CACHE. Reflect changes above. |
