* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* .cvsignore: Added aclocal.m4 and configure.
* .cvsignore: New file.
* ChangeLog: New.
* configure.ac: New.
* Makefile.am: New.
* rtems/*: Copied from c/src/exec/rtems/optman.
* sapi/*: Copied from c/src/exec/sapi/optman.
* src/Makefile.am: Add multilib support.
* optman/Makefile.am: Add multilib support.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* optman/Makefile.am, src/Makefile.am: Include compile.am.
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
it work.
MP_packet_Classes
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
