* optman/Makefile.am, optman/preinstall.am, optman/rtems/no-dpmem.c,
optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c,
optman/rtems/no-part.c, optman/rtems/no-region.c,
optman/rtems/no-rtmon.c, optman/rtems/no-sem.c,
optman/rtems/no-signal.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c: Add optional manager stub for Barrier. Simplify
other optional managers so using them reduces application size
instead of increasing it.
* optman/rtems/no-barrier.c: New file.
PR 1181/bsps
* optman/rtems/no-msg.c: Clean up dead code.
* optman/rtems/no-sem.c: Semaphores are rtems_id not Object_id.
* optman/rtems/no-region.c: Reflect having changed
rtems_region_get_segment_size.
* optman/rtems/no-dpmem.c, optman/rtems/no-mp.c,
optman/rtems/no-msg.c, optman/rtems/no-part.c,
optman/rtems/no-region.c, optman/rtems/no-rtmon.c,
optman/rtems/no-sem.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert to using c99
fixed size types.
* rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c,
rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c,
rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL
for license changed.
* Makefile.am: Merge-in rtems/Makefile.am and sapi/Makefile.am.
* sapi/Makefile.am: Removed.
* rtems/Makefile.am: Removed.
* rel.am: Removed.
* configure.ac: Add RTEMS_BSP_CHECK_CACHE.
Reflect changes above.
* rtems/Makefile.am: Reworked.
* sapi/Makefile.am: Reworked.
* rel.am: New.
* rtems/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Add bsplib_DATA = $(PGMS).
Remove ASM4FLAGS.
* rtems/Makefile.am: Add bsplib_DATA = $(PGMS).
* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ChangeLog: New.
* configure.ac: New.
* Makefile.am: New.
* rtems/*: Copied from c/src/exec/rtems/optman.
* sapi/*: Copied from c/src/exec/sapi/optman.
* src/Makefile.am: Add multilib support.
* optman/Makefile.am: Add multilib support.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* optman/Makefile.am, src/Makefile.am: Include compile.am.
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
it work.
MP_packet_Classes
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
