* rtems/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Use .$(OBJEXT) instead of .o.
* sapi/Makefile.am: Add bsplib_DATA = $(PGMS).
Remove ASM4FLAGS.
* rtems/Makefile.am: Add bsplib_DATA = $(PGMS).
* sapi/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ChangeLog: New.
* configure.ac: New.
* Makefile.am: New.
* rtems/*: Copied from c/src/exec/rtems/optman.
* sapi/*: Copied from c/src/exec/sapi/optman.
* src/Makefile.am: Add multilib support.
* optman/Makefile.am: Add multilib support.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* optman/Makefile.am, src/Makefile.am: Include compile.am.
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
it work.
MP_packet_Classes
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
