path: root/c/src/optman/rtems/no-timer.c (follow)
* modified to generate fatal error when an unconfigured directive is invoked.Joel Sherrill1996-04-191-0/+36
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-20/+23
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+84
