* optman/rtems/no-sem.c: Semaphores are rtems_id not Object_id.
* optman/rtems/no-dpmem.c, optman/rtems/no-mp.c,
optman/rtems/no-msg.c, optman/rtems/no-part.c,
optman/rtems/no-region.c, optman/rtems/no-rtmon.c,
optman/rtems/no-sem.c, optman/rtems/no-timer.c,
optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert to using c99
fixed size types.
* rtems/no-dpmem.c, rtems/no-event.c, rtems/no-mp.c, rtems/no-msg.c,
rtems/no-part.c, rtems/no-region.c, rtems/no-rtmon.c, rtems/no-sem.c,
rtems/no-signal.c, rtems/no-timer.c, sapi/no-ext.c, sapi/no-io.c: URL
for license changed.
like signal dispatching.
correct Information block.
