path: root/c/src/optman/rtems/no-part.c (follow)
* modified to generate fatal error when an unconfigured directive is invoked.Joel Sherrill1996-04-191-0/+26
* posix support initially addedJoel Sherrill1995-09-261-3/+3
* More file movementJoel Sherrill1995-09-211-1/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-9/+10
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+71
