* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -2/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 11 | -32/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 3 | -0/+9 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 3 | -9/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 2 | -19/+0 |
* | Revert "Support custom Makefiles." | Sebastian Huber | 2012-01-26 | 3 | -61/+1 |
| | | | | This reverts commit 621e1c9b74272ff94efec749c6c4a673a7c315e8. | ||||
* | Support custom Makefiles. | Sebastian Huber | 2012-01-23 | 3 | -1/+61 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 4 | -55/+7 |
| | | | | | | PR 1589/build * leaf.cfg, target.cfg.in, compilers/gcc-target-default.cfg: Remove obsolete optional manager capability. | ||||
* | 2011-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-16 | 2 | -5/+4 |
| | | | | * Makefile.am: Don't generate host.cfg.in. | ||||
* | 2011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-04-01 | 5 | -0/+12 |
| | | | | | * Makefile.am, Makefile.inc.in, configure.ac, target.cfg.in: Update to account for movement of .cfg files. | ||||
* | 2011-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-29 | 2 | -41/+45 |
| | | | | * Makefile.am: Use '|' as sed-delimiter. | ||||
* | 2011-03-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-09 | 2 | -2/+7 |
| | | | | | PR 1760/misc * compilers/gcc-target-default.cfg: Fix typo in CPP definition. | ||||
* | 2011-03-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-08 | 2 | -5/+9 |
| | | | | | * Makefile.inc.in: Fix PROJECT_ROOT to match usage in templates and existing Makefiles. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 3 | -4/+67 |
| | | | | * Makefile.am, configure.ac: Move file generation into Makefile. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 2 | -1/+5 |
| | | | | * Makefile.inc.in: Set PROJECT_ROOT = @pkgdatadir@. | ||||
| | | | | * Makefile.am: Install *.cfgs into $(pkgdatadir)/make. | ||||
* | 2011-03-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-07 | 2 | -2/+5 |
| | | | | | PR 1753/misc: * host.cfg.in: Remove RTEMS_HOST. | ||||
* | 2011-03-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-05 | 2 | -5/+5 |
| | | | | | PR 1754/misc: * host.cfg.in: Remove GCCSED. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-27 | 2 | -0/+10 |
| | | | | | | PR 1532/testing * host.cfg.in: Add initial tests for untar capabilities. This required BIN2C. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 7 | -55/+9 |
| | | | | | | * Makefile.inc.in, bsp.cfg.in, configure.ac, target.cfg.in: Remove itron. * aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -3/+3 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -4/+7 |
| | | | | * bsp.mak: Remove RTEMS_BSP_FAMILY. | ||||
* | Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | Ralf Corsepius | 2009-10-16 | 1 | -2/+0 |
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+4 |
| | | | | * configure.ac: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+6 |
| | | | | | | * aclocal/enable-bare.m4: Remove (Abandoned). * bsp.cfg.in: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. * configure.ac: Remove RTEMS_ENABLE_BARE. | ||||
* | Remove RTEMS_ENABLE_BARE. | Ralf Corsepius | 2009-10-16 | 1 | -1/+0 |
* | Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | Ralf Corsepius | 2009-10-16 | 1 | -4/+0 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -19/+0 |
* | 2009-07-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-07-23 | 2 | -1/+5 |
| | | | | * aclocal/enable-itron.m4: Default to not building itron. | ||||
* | 2009-04-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-04-15 | 2 | -3/+7 |
| | | | | * leaf.cfg: Remove hard-coded .exe. | ||||
* | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-18 | 4 | -24/+5 |
| | | | | | * leaf.cfg, compilers/gcc-target-default.cfg, custom/default.cfg.in: Eliminate START_BASE and START_FILE. | ||||
* | 2008-09-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-15 | 2 | -2/+8 |
| | | | | | | * leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in make-exe and make-cxx-exe definitions. This was resulting in the linker script being processed twice and breaking some BSPs. | ||||
* | 2008-09-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-09 | 3 | -19/+9 |
| | | | | | | * leaf.cfg, compilers/gcc-target-default.cfg: Remove use of AM_LDFLAGS. Ensure LDFLAGS works all the time. Clean up BSPs which defined their own make-exe rules inappropriately. | ||||
* | 2008-05-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-05-20 | 2 | -2/+8 |
| | | | | * leaf.cfg: Do not override bsp-post-link. | ||||
* | 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-03-11 | 2 | -0/+41 |
| | | | | | * leaf.cfg: Switch to explicit .exe instead of EXEEXT to get it to work. Primarily move the executable transformation rules to leaf.cfg. | ||||
* | 2007-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-18 | 2 | -0/+7 |
| | | | | * Makefile.inc.in: Add CXX and CXX_FOR_TARGET. | ||||
* | 2007-08-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-08-04 | 3 | -2/+7 |
| | | | | | * bsp.cfg.in: Hard-code HAS_RDBG = no. * target.cfg.in: Hard-code RTEMS_HAS_RDBG = no. | ||||
* | 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-02 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RDBG. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -1/+6 |
| | | | | | * target.cfg.in: region, extension and semaphore are no longer required. | ||||
* | 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-09 | 2 | -6/+7 |
| | | | | * leaf.cfg: Add optional manager stub for Barrier. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+7 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 2 | -3/+4 |
| | | | | * aclocal/check-itron.m4: Allow unix. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -1/+0 |
| | | | | * make/bsp.mak: Remove CFLAGS_DEBUG_V. | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -0/+15 |
| | | | | * aclocal/rtems-flags.new: New (moved from ../aclocal). | ||||
* | 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-22 | 2 | -0/+20 |
| | | | | * aclocal/enable-itron.m4: New (moved from ../aclocal). | ||||
* | 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-21 | 1 | -0/+19 |
| | | | | * aclocal/enable-bare.m4: New (moved from aclocal). | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. |
