* configure.ac: SIZE, NM, OBJCOPY.
* target.cfg.in: Remove RTEMS_USE_MACROS.
* Makefile.inc.in: Remove RTEMS_USE_MACROS.
* aclocal/enable-inlines.m4: Removed.
* configure.ac: Remove RTEMS_ENABLE_INLINES.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* configure.ac: Remove RTEMS_PATH_PERL (Unused).
* aclocal/check-itron.m4: New.
* aclocal/enable-inlines.m4: New.
* Makefile.am: Add -I aclocal to ACLOCAL_AMFLAGS.
* bsp.mak: Remove support for profile-variant.
* configure.ac: Ditto.
* directory.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* make/README: Remove references to profile-variant.
* bsp.mak: Use ac_cv_env instead of ac_cv for cached vars.
* target.cfg.in: New, copy of c/make/target.cfg.in.
* configure.ac: Add target.cfg.
* Makefile.am: Add target.cfg.
* Makefile.am: Don't include @RTEMS_BSP@.cfg (unused).
* compilers/gcc-target-default.cfg: Make build variants work
for user applications.
* Makefile.inc.in: Remove RTEMS_USE_GCC272, RTEMS_LIBC_DIR.
* compilers/gcc-target-default.cfg: Remove obsolete reference to
src/libxil/Makefile.
Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc
-spec).
* compilers/gcc-target-default.cfg: Add -qrtems-debug handling.
* configure.ac: Only symlink leaf.cfg.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* lib.cfg: Ditto.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Part of addressing PR281.
* main.cfg: Added recognition of VARIANT=DEBUG on command line.
* compilers/gcc-target-default.cfg: Removed remaining support for
RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug
as one of the LDFLAGS when the debug variant is specified.
* Makefile.inc.in: Comment out RTEMS_USE_GCC272.
Comment out RTEMS_LIBC_DIR.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
* bsp.mak: New.
* Makefile.am: Remove RTEMS_BSP.cache generation.
Remove handling custom/*.cfgs.
Remove handling custom/default.cfg.
* configure.ac: Remove handling of custom/*.cfgs.
Remove auto* generated custom/default.cfg.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* compilers/gcc-target-default.cfg: Add missing \.
Reported by Ilya Alexeev <ilya@continuum.ru>.
* custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS.
* custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272
support.
* custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* configure.in: Remove.
* configure.in: Reworked for autoconf-2.52.
* leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V.
* compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags,
remove unused flags, remove -ansi from CPP.
* custom/eth_comm.cfg: Remove CPU_DEFINES.
* custom/sim68000.cfg: Remove CPU_DEFINES.
* compilers/gcc-no_bsp.cfg: Remove -ansi -fasm.
* compilers/gcc-default.cfg: Dito.
* compilers/gcc-portsw.cfg: Remove -Hansi.
* custom/posix.cfg: Remove inclusion of target.cfg.
* custom/simhppa.cfg: Remove -ansi -fasm.
