line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
In case a BSP selects special CFLAGS_OPTIMIZE_V flags then they will be
also used for CXXFLAGS_OPTIMIZE_V automatically for example.
The -g flag is set by the BSP.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
This reverts commit 621e1c9b74272ff94efec749c6c4a673a7c315e8.
PR 1589/build
* leaf.cfg, target.cfg.in, compilers/gcc-target-default.cfg: Remove
obsolete optional manager capability.
* Makefile.am: Don't generate host.cfg.in.
* Makefile.am, Makefile.inc.in, configure.ac, target.cfg.in: Update to
account for movement of .cfg files.
* Makefile.am: Use '|' as sed-delimiter.
PR 1760/misc
* compilers/gcc-target-default.cfg: Fix typo in CPP definition.
* Makefile.inc.in: Fix PROJECT_ROOT to match usage in templates and
existing Makefiles.
* Makefile.am, configure.ac: Move file generation into Makefile.
* Makefile.inc.in: Set PROJECT_ROOT = @pkgdatadir@.
* Makefile.am: Install *.cfgs into $(pkgdatadir)/make.
PR 1753/misc:
* host.cfg.in: Remove RTEMS_HOST.
PR 1754/misc:
* host.cfg.in: Remove GCCSED.
PR 1532/testing
* host.cfg.in: Add initial tests for untar capabilities. This required
BIN2C.
* Makefile.inc.in, bsp.cfg.in, configure.ac, target.cfg.in:
Remove itron.
* aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove.
* bsp.mak: Remove RTEMS_BSP_FAMILY.
* configure.ac: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS.
* aclocal/enable-bare.m4: Remove (Abandoned).
* bsp.cfg.in: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS.
* configure.ac: Remove RTEMS_ENABLE_BARE.
* aclocal/enable-itron.m4: Default to not building itron.
* leaf.cfg: Remove hard-coded .exe.
* leaf.cfg, compilers/gcc-target-default.cfg, custom/default.cfg.in:
Eliminate START_BASE and START_FILE.
* leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in
make-exe and make-cxx-exe definitions. This was resulting in the
linker script being processed twice and breaking some BSPs.
* leaf.cfg, compilers/gcc-target-default.cfg: Remove use of AM_LDFLAGS.
Ensure LDFLAGS works all the time. Clean up BSPs which defined their
own make-exe rules inappropriately.
* leaf.cfg: Do not override bsp-post-link.
* leaf.cfg: Switch to explicit .exe instead of EXEEXT to get it to
work. Primarily move the executable transformation rules to leaf.cfg.
