* leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V.
* compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS.
* compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags,
remove unused flags, remove -ansi from CPP.
* custom/eth_comm.cfg: Remove CPU_DEFINES.
* custom/sim68000.cfg: Remove CPU_DEFINES.
* compilers/gcc-no_bsp.cfg: Remove -ansi -fasm.
* compilers/gcc-default.cfg: Dito.
* compilers/gcc-portsw.cfg: Remove -Hansi.
* custom/posix.cfg: Remove inclusion of target.cfg.
* custom/simhppa.cfg: Remove -ansi -fasm.
* Makefile.am: Use exec_prefix not prefix.
* lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg
* main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP).
* host.cfg.in: Remove RM, make-script.
* ChangeLog: Remove bogus 2001-01-22 entry.
* Makefile.inc.in: Add exec_prefix, remove terminating / from
PROJECT_ROOT.
* host.cfg.in: Update from <toplevel>/make/host.cfg.in
* Makefile.inc.in: Remove RTEMS_HOST.
* Makefile.inc.in: Use * instead of *_FOR_TARGET (BUG-FIX).
* Makefile.am: Switch to GNU canonicalized autoconf macros.
* leaf.cfg: Remove Depends inclusion.
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
that does some cleanup:
* remove c/src/make/main.cfg.in (obsolete, unused) and any reference to it.
* remove RTEMS_BSP_SPECS from c/src/make/custom/default.cfg.in (unused)
All files being effected by this patch are only used when building
RTEMS, therefore this patch should not have any side-effects outside
of the source- rsp. build-tree.
significant things:
and PowerPC
same code base.
rtems-rc-4.5.0-7.diff. This file is being added to the main branch
in hopes that it will be easier to deal with the full merge later.
that contains:
* Removes MKLIB
handling)
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<corsepiu@faw.uni-ulm.de> which corrects some configuration
problems and cleans up a few Makefile.in's.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
for RTEMS.
host programs are now compiled with automake generated rules. This was
done after discussions with Ralf Corsepius and Eric Norum.
and not likely to become so. Comments on each configuration
are below.
+ Force CPU386 - This BSP was developed as part of the initial
port of RTEMS to the i386. This board has been unavailable
for a long time now.
+ GO32 - This BSP and some CPU code supported djgpp v1.x. This
version is now quite old. No one has stepped forward to
update the code to v2.x which may be technically impossible
anyway. More importantly, go32 has been superceded by the pc386 BSP.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
from Eric Norum <eric@cls.usask.ca>. This patch was rtems-19990820-0-diff
from Ralf.
FYI: In parallel to the transition to automake, RTEMS is on a transition
from make-time configuration to per-bsp and per-bsp configuration at
configuration-time. Due to this several changes to configuration files
have been added and might have broken something that has been working
previously. Most noticeable behavioral change is that you now are required
to use @RTEMS_BSP@ instead of $(RTEMS_BSP) inside of any Makefile.ins
which are configured or build as part of the source-tree.
> It used to be that only RTEMS_MAKEFILE_PATH had to be set. Why is this
> no longer sufficient?
It should still be working, if it doesn't, it has to be considered to be
broken and should be fixed.
I am not sure, but I assume you are using Makefile.inc - In this case, you
have found a bug in Makefile.inc.in which should be worked-around by the
patch below. If my assumption is wrong, I would need more details ...
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
problem with the HAS_MP patch and regenerated files.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
FYI: I am not talking about using "make -C <dir>", which probably
is much faster on M$ hosts than RTEMS's implementation, but about
removing --enable-gmake-print support and to apply a variant of
automake's subdirectory.
Automake's subdirectory rule seems to be a little bit faster, but I
wouldn't bet on this.
Attached to this mail is my proposal.
After applying the patch, please run
cvs rm aclocal/enable-gmake-print.m4
