path: root/c/src/make (follow)
* 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-042-3/+4
| | | | * aclocal/check-itron.m4: Allow unix.
* 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-041-1/+0
| | | | * make/bsp.mak: Remove CFLAGS_DEBUG_V.
* 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-052-0/+15
| | | | * aclocal/rtems-flags.new: New (moved from ../aclocal).
* 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-222-0/+20
| | | | * aclocal/enable-itron.m4: New (moved from ../aclocal).
* 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-211-0/+19
| | | | * aclocal/enable-bare.m4: New (moved from aclocal).
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-242-1/+5
| | | | * configure.ac: Require automake > 1.9.
* 2004-03-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-092-2/+7
| | | | * configure.ac: SIZE, NM, OBJCOPY.
* Remove refs to Makefile*.Ralf Corsepius2004-03-091-2/+0
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-022-1/+6
| | | | | | | * target.cfg.in: Remove RTEMS_USE_MACROS. * Makefile.inc.in: Remove RTEMS_USE_MACROS. * aclocal/enable-inlines.m4: Removed. * configure.ac: Remove RTEMS_ENABLE_INLINES.
* 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-245-20/+7
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-222-2/+4
| | | | * configure.ac: Remove RTEMS_CANONICAL_HOST.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-213-3/+8
| | | | | | * configure.ac: Remove RTEMS_CHECK_CPU. * aclocal/check-itron.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* 2003-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-172-1/+4
| | | | * configure.ac: Remove RTEMS_PATH_PERL (Unused).
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-184-1/+61
| | | | | | * aclocal/check-itron.m4: New. * aclocal/enable-inlines.m4: New. * Makefile.am: Add -I aclocal to ACLOCAL_AMFLAGS.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-182-1/+5
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-1/+1
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-162-1/+5
| | | | Makefile.am: Reflect having moved automake.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Changed format so script will see PR number.Joel Sherrill2003-06-131-0/+1
* 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-061-1/+1
| | | | | | | | * bsp.mak: Remove support for profile-variant. * configure.ac: Ditto. * directory.cfg: Ditto. * compilers/gcc-target-default.cfg: Ditto. * make/README: Remove references to profile-variant.
* 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-065-35/+24
* Merger from rtems-4-6-branch.Ralf Corsepius2003-04-182-6/+12
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-122-6/+10
| | | | * bsp.mak: Use ac_cv_env instead of ac_cv for cached vars.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-062-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-294-2/+69
| | | | | | * target.cfg.in: New, copy of c/make/target.cfg.in. * configure.ac: Add target.cfg. * Makefile.am: Add target.cfg.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-202-2/+4
| | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg (unused).
* 2002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-182-7/+11
| | | | | * compilers/gcc-target-default.cfg: Make build variants work for user applications.
* 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-132-4/+4
| | | | * Makefile.inc.in: Remove RTEMS_USE_GCC272, RTEMS_LIBC_DIR.
* 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-132-2/+9
| | | | | | | * compilers/gcc-target-default.cfg: Remove obsolete reference to src/libxil/Makefile. Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc -spec).
* 2002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-122-4/+11
| | | | * compilers/gcc-target-default.cfg: Add -qrtems-debug handling.
* 2002-11-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-082-10/+6
| | | | * configure.ac: Only symlink leaf.cfg.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-072-10/+13
| | | | | | | | | * configure.ac: Remove references to Templates. Use local AC_CONFIG_LINKS. * README: Relocated from make/ * directory.cfg: Ditto. * lib.cfg: Ditto. * compilers/gcc-target-default.cfg: Ditto.
* 2002-11-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-052-3/+6
| | | | | * configure.ac: Unconditionally check for CXX (Hack to bug in autoconf > 2.54).
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-4/+10
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-131-77/+2
| | | | | | | | * Part of addressing PR281. * main.cfg: Added recognition of VARIANT=DEBUG on command line. * compilers/gcc-target-default.cfg: Removed remaining support for RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug as one of the LDFLAGS when the debug variant is specified.
* 2002-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-062-2/+9
| | | | | * Makefile.inc.in: Comment out RTEMS_USE_GCC272. Comment out RTEMS_LIBC_DIR.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-092-1/+7
| | | | | * configure.ac: Remove RTEMS_BSP_ALIAS. Add RTEMS_CHECK_BSP_CACHE.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-092-0/+20
| | | | * bsp.mak: New.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-093-42/+9
| | | | | | | | * Makefile.am: Remove RTEMS_BSP.cache generation. Remove handling custom/*.cfgs. Remove handling custom/default.cfg. * configure.ac: Remove handling of custom/*.cfgs. Remove auto* generated custom/default.cfg.
* 2002-04-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-016-42/+38
| | | | | | | | | * custom/Makefile.am: Remove. * compilers/Makefile.am: Remove. * compilers/.cvsignore: Remove. * Makefile.am: Merge-in former */Makefile.ams. Add more vars to <BSP>.cache. * configure.ac: Reflect changes above. Cosmetic fixes.
* 2002-04-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-162-2/+4
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * compilers/Makefile.am: Remove AUTOMAKE_OPTIONS. * custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-1/+1
| | | | | * compilers/gcc-target-default.cfg: Add missing \. Reported by Ilya Alexeev <ilya@continuum.ru>.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-1/+2
| | | | | | | * custom/genmongoosev.cfg: Remove -g from CPU_CFLAGS. * custom/h8sim.cfg: Remove -g from CPU_CFLAGS. Remove GCC272 support. * custom/jmr3904.cfg: Remove -g from CPU_CFLAGS. Remove GCC272.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+137
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
