* | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-18 | 4 | -24/+5 |
| | | | | | * leaf.cfg, compilers/gcc-target-default.cfg, custom/default.cfg.in: Eliminate START_BASE and START_FILE. | ||||
* | 2008-09-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-15 | 2 | -2/+8 |
| | | | | | | * leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in make-exe and make-cxx-exe definitions. This was resulting in the linker script being processed twice and breaking some BSPs. | ||||
* | 2008-09-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-09 | 3 | -19/+9 |
| | | | | | | * leaf.cfg, compilers/gcc-target-default.cfg: Remove use of AM_LDFLAGS. Ensure LDFLAGS works all the time. Clean up BSPs which defined their own make-exe rules inappropriately. | ||||
* | 2008-05-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-05-20 | 2 | -2/+8 |
| | | | | * leaf.cfg: Do not override bsp-post-link. | ||||
* | 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-03-11 | 2 | -0/+41 |
| | | | | | * leaf.cfg: Switch to explicit .exe instead of EXEEXT to get it to work. Primarily move the executable transformation rules to leaf.cfg. | ||||
* | 2007-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-18 | 2 | -0/+7 |
| | | | | * Makefile.inc.in: Add CXX and CXX_FOR_TARGET. | ||||
* | 2007-08-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-08-04 | 3 | -2/+7 |
| | | | | | * bsp.cfg.in: Hard-code HAS_RDBG = no. * target.cfg.in: Hard-code RTEMS_HAS_RDBG = no. | ||||
* | 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-02 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RDBG. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -1/+6 |
| | | | | | * target.cfg.in: region, extension and semaphore are no longer required. | ||||
* | 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-09 | 2 | -6/+7 |
| | | | | * leaf.cfg: Add optional manager stub for Barrier. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+7 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 2 | -3/+4 |
| | | | | * aclocal/check-itron.m4: Allow unix. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -1/+0 |
| | | | | * make/bsp.mak: Remove CFLAGS_DEBUG_V. | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -0/+15 |
| | | | | * aclocal/rtems-flags.new: New (moved from ../aclocal). | ||||
* | 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-22 | 2 | -0/+20 |
| | | | | * aclocal/enable-itron.m4: New (moved from ../aclocal). | ||||
* | 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-21 | 1 | -0/+19 |
| | | | | * aclocal/enable-bare.m4: New (moved from aclocal). | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-03-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-09 | 2 | -2/+7 |
| | | | | * configure.ac: SIZE, NM, OBJCOPY. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 2 | -1/+6 |
| | | | | | | | * target.cfg.in: Remove RTEMS_USE_MACROS. * Makefile.inc.in: Remove RTEMS_USE_MACROS. * aclocal/enable-inlines.m4: Removed. * configure.ac: Remove RTEMS_ENABLE_INLINES. | ||||
* | 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-24 | 5 | -20/+7 |
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 3 | -3/+8 |
| | | | | | | * configure.ac: Remove RTEMS_CHECK_CPU. * aclocal/check-itron.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. | ||||
* | 2003-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-17 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_PATH_PERL (Unused). | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 4 | -1/+61 |
| | | | | | | * aclocal/check-itron.m4: New. * aclocal/enable-inlines.m4: New. * Makefile.am: Add -I aclocal to ACLOCAL_AMFLAGS. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -1/+5 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Changed format so script will see PR number. | Joel Sherrill | 2003-06-13 | 1 | -0/+1 |
* | 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-06-06 | 1 | -1/+1 |
| | | | | | | | | * bsp.mak: Remove support for profile-variant. * configure.ac: Ditto. * directory.cfg: Ditto. * compilers/gcc-target-default.cfg: Ditto. * make/README: Remove references to profile-variant. | ||||
* | 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-06-06 | 5 | -35/+24 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-04-18 | 2 | -6/+12 |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-12 | 2 | -6/+10 |
| | | | | * bsp.mak: Use ac_cv_env instead of ac_cv for cached vars. | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-29 | 4 | -2/+69 |
| | | | | | | * target.cfg.in: New, copy of c/make/target.cfg.in. * configure.ac: Add target.cfg. * Makefile.am: Add target.cfg. | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-20 | 2 | -2/+4 |
| | | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg (unused). | ||||
* | 2002-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-18 | 2 | -7/+11 |
| | | | | | * compilers/gcc-target-default.cfg: Make build variants work for user applications. | ||||
* | 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-13 | 2 | -4/+4 |
| | | | | * Makefile.inc.in: Remove RTEMS_USE_GCC272, RTEMS_LIBC_DIR. | ||||
* | 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-13 | 2 | -2/+9 |
| | | | | | | | * compilers/gcc-target-default.cfg: Remove obsolete reference to src/libxil/Makefile. Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc -spec). | ||||
* | 2002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-12 | 2 | -4/+11 |
| | | | | * compilers/gcc-target-default.cfg: Add -qrtems-debug handling. | ||||
* | 2002-11-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-08 | 2 | -10/+6 |
| | | | | * configure.ac: Only symlink leaf.cfg. | ||||
* | 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-07 | 2 | -10/+13 |
| | | | | | | | | | * configure.ac: Remove references to Templates. Use local AC_CONFIG_LINKS. * README: Relocated from make/ * directory.cfg: Ditto. * lib.cfg: Ditto. * compilers/gcc-target-default.cfg: Ditto. | ||||
* | 2002-11-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-05 | 2 | -3/+6 |
| | | | | | * configure.ac: Unconditionally check for CXX (Hack to bug in autoconf > 2.54). |
