* leaf.cfg: Remove Depends inclusion.
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
that does some cleanup:
* remove c/src/make/main.cfg.in (obsolete, unused) and any reference to it.
* remove RTEMS_BSP_SPECS from c/src/make/custom/default.cfg.in (unused)
All files being effected by this patch are only used when building
RTEMS, therefore this patch should not have any side-effects outside
of the source- rsp. build-tree.
significant things:
and PowerPC
same code base.
rtems-rc-4.5.0-7.diff. This file is being added to the main branch
in hopes that it will be easier to deal with the full merge later.
that contains:
* Removes MKLIB
handling)
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<corsepiu@faw.uni-ulm.de> which corrects some configuration
problems and cleans up a few Makefile.in's.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
for RTEMS.
host programs are now compiled with automake generated rules. This was
done after discussions with Ralf Corsepius and Eric Norum.
and not likely to become so. Comments on each configuration
are below.
+ Force CPU386 - This BSP was developed as part of the initial
port of RTEMS to the i386. This board has been unavailable
for a long time now.
+ GO32 - This BSP and some CPU code supported djgpp v1.x. This
version is now quite old. No one has stepped forward to
update the code to v2.x which may be technically impossible
anyway. More importantly, go32 has been superceded by the pc386 BSP.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
from Eric Norum <eric@cls.usask.ca>. This patch was rtems-19990820-0-diff
from Ralf.
FYI: In parallel to the transition to automake, RTEMS is on a transition
from make-time configuration to per-bsp and per-bsp configuration at
configuration-time. Due to this several changes to configuration files
have been added and might have broken something that has been working
previously. Most noticeable behavioral change is that you now are required
to use @RTEMS_BSP@ instead of $(RTEMS_BSP) inside of any Makefile.ins
which are configured or build as part of the source-tree.
> It used to be that only RTEMS_MAKEFILE_PATH had to be set. Why is this
> no longer sufficient?
It should still be working, if it doesn't, it has to be considered to be
broken and should be fixed.
I am not sure, but I assume you are using Makefile.inc - In this case, you
have found a bug in Makefile.inc.in which should be worked-around by the
patch below. If my assumption is wrong, I would need more details ...
This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
problem with the HAS_MP patch and regenerated files.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
FYI: I am not talking about using "make -C <dir>", which probably
is much faster on M$ hosts than RTEMS's implementation, but about
removing --enable-gmake-print support and to apply a variant of
automake's subdirectory.
Automake's subdirectory rule seems to be a little bit faster, but I
wouldn't bet on this.
Attached to this mail is my proposal.
After applying the patch, please run
cvs rm aclocal/enable-gmake-print.m4
are:
is long but I hate to lose the information so I am including it here.
> I am still fixing and recompiling but this is the issue that was not the
> result of another patch. This is a fundamental build issue that I value
> your opinion on.
This is difficult issue (I.e. I have no destinct solution for it)
Background:
(gnu-) make's implicit rules apply CFLAGS, CPPFLAGS, CXXFLAGS, ASFLAGS and
LDFLAGS (cf. make.info/Implicit Rules/Catalogue of Rules), only.
In brief:
CPPFLAGS .. passed to the c-preprocessor
CFLAGS ... passed to the c-compiler
CXXFLAGS ... equivalent to CFLAGS but passed to the c++ compiler
(Attention: CFLAGS is not passed to the c++ compiler)
ASFLAGS .. equivalent to CFLAGS, but passed to the assembler
LDFLAGS .. equivalent to CFLAGS, but passed to the linker
A bit oversimplifying, these make rules are as follows
.c.o:
$(CC) $(CPPFLAGS) $(CFLAGS) -c
.cc.o:
$(CXX) $(CPPFLAGS) $(CXXFLAGS) -c
.S.s:
$(CPP) $(CPPFLAGS)
.s.o:
$(AS) $(ASFLAGS)
My reading of the documentation (make.info) is that {AS|AR|CC|CXX|CPP}FLAGS
are ment to be passed to the related tools directly, however examinating
the rule set of gmake (gmake -p -f /dev/null") shows that many rules use
$(CC) instead of the related tools (eg. linker rules) etc.
I.e. these flags should not rely on being passed through cpp or gcc. With
gcc being the common frontend for all of these tools of a gnu-toolchain the
situation becomes difficult (Which option is passed to whom and which tool
really uses it?), because these variable can also contain the toolchain's
frontend (eg. AS=gcc, LD=gcc, CPP=gcc -E).
For some commonly used options the situation is quite clear:
* -g -> CFLAGS
* -OX -> CFLAGS
* -D -> CPPFLAGS
* -A -> CPPFLAGS
But where to add -m, -B, -specs, -qrtems_XXX ?
* -B, -specs, -qrtems_XXX are gcc-frontend options
* -m is a combinations of flags to go to different destinations, in many
(all?) cases, the following is valid
-m is expanded by gcc into a set of -D and -A options
-m is interpreted by cc1 as a machine flag to generate a specific
instruction set.
-m is interpreted by gcc as an implicit linker search path for multilibs to
set up calls to LD.
>From my point of view this indicates we can either destingush between these
different usages (= separately add -m to CFLAGS, LDFLAGS etc) or to add it
to CPPFLAGS and use gcc (the frontend) instead of calling each tool
directly (less error prone) -- I vote for CPPFLAGS, but I am not sure.
Now, where to add CPU_CFLAGS?
AFAIS, in probably all cases CPU_CFLAGS contain -D -A, and -m options,
only.
* -D and -A are supposed to go to CPPFLAGS
* -mXXX options can have multiple meanings (It can be gcc, collect2/ld and
cc1/cc1plus option simultaneously)
Here, I made a mistake - I destinguished between CPU_DEFINES to be added to
CPPFLAGS and CPU_CFLAGS to be added to CFLAGS and CXXFLAGS (cf.
gcc-target-default.cfg), generally assuming CPU_CFLAGS are CFLAGS.
This breaks preprocessing *.S into *.i files because CPU_CFLAGS flags were
not added to CPPFLAGS. Hence *all* *.S were compiled without taking
-mXX-flags into account. The i960/cvme BSP was the only one which
explicitly checked for a specific -m flag (-mca) and refused to compile
without it -- all other CPUs/BSPs silently swallowed this.
IMO, we can either
1) add CPU_CFLAGS and CPU_DEFINES to CPPFLAGS, thus silently convert
CPU_CFLAGS's meaning into CPU_DEFINES (Alternative solution: rename
CPU_CFLAGS to CPU_DEFINES and merge CPU_FLAGS with CPU_DEFINES).
or
2) destinguish between CPU_DEFINES and CPU_CFLAGS. In this case we would
need to check the contents of each CPU_CFLAGS in custom/*.cfg and move the
some parts of the contents to CPU_DEFINES and keep other parts in
CPU_CFLAGS (CFLAGS must contain options for the c/c++-compiler only!).
Though Solution 2) is the clearer one, I implemented 1) which is the
simplier one (the patch below).
ATTENTION: This patch is small in size, but affects almost everything.
Additional complications araise with linking:
Some BSPs call LD and AS directly (esp. gcc-2.7 make-exe rules). If LD=gcc
then LDFLAGS are supposed to be gcc-options, but if LD=ld then LDFLAGS is
supposed to contain ld-options.
An analog thought is valid for AS, but luckily enough ASFLAGS is not used
of inside the whole source tree.
Most RTEMS' custom/*.cfg use $(CC) $(CFLAGS) to link with gcc-2.8 make-exe
rules. With the patch below (CPU_CFLAGS added to CPPFLAGS) this means
CPU_CFLAGS will not be passed to the linker, which is incorrect for
multilibbed CPU's.
gmake's default rule set contains a variety of rules for linking, all
ending up in calling $(CC) $(LDFLAGS) for linking at their very end.
IMO, this means we should use something like
LINK.o = $(CC) $(LDFLAGS) in gcc-target-default.cfg
+ modify all gcc-2.8 make-exe rules to use
$(LINK.o) .......
+ setup LDFLAGS according to the requirements of the above.
I.e. we should use $(CC) for linking instead of calling the linker (LD)
directly and set LDFLAGS = $(CPPFLAGS) $(CFLAGS) or similar.
> 2) rtems-rc-19990131-1.diff
> Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt
> the flags/makefile variables to automake and make standards (cf.
> make.info - implicit rules/variables).
> This patch is rather risky and may probably break things, but is an
> essential step towards automake.
> FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong,
> as I had to experience ;-.
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
used in gcc.
I have managed to build the bsp ods68302 and the rtti test case I made
with egcs-1.1b and binutils-2.9.1.
I have built our C++ application and got no link errors so it looks like
this is now working. I am yet to test the code but getting the thing to
link was the problem.
Please find a patch attached which removes the -fno-rtti option.
