The last installed tool in RTEMS repository is the install-if-change
script. It is not used to build/install BSPs. This script does the
same as the standard "install" program with an additional feature to
install variants via the -V command line option.
This script is used by the standard Makefile support:
c/src/make/host.cfg.in:INSTALL_CHANGE=$(PROJECT_BIN)/install-if-change
The INSTALL_CHANGE is used by:
c/src/make/host.cfg.in:ifndef INSTALL_CHANGE
c/src/make/host.cfg.in:INSTALL_VARIANT=$(INSTALL_CHANGE) -V
"$(LIB_VARIANT)"
Remove the support for variant installation and instead use the standard
"install" program. This breaks application Makefiles using the standard
Makefile support of RTEMS.
Close #3455.
Do not document CFLAGS_DEBUG_OPTIMIZE_V, since this flag is not used.
All tools should be removed from the RTEMS source repository at some
point in time. Tools with a BSD-style license will be moved to the
RTEMS tools repository. Unfortunately, this tool has no license
information.
Remove all uses of this tool from the code base. Users of HEX files
should consider to use ELF instead.
Close #3379.
This tool is now included in the RTEMS tools repository.
Close #3380.
upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
In case a BSP selects special CFLAGS_OPTIMIZE_V flags then they will be
also used for CXXFLAGS_OPTIMIZE_V automatically for example.
The -g flag is set by the BSP.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
This reverts commit 621e1c9b74272ff94efec749c6c4a673a7c315e8.
PR 1589/build
* leaf.cfg, target.cfg.in, compilers/gcc-target-default.cfg: Remove
obsolete optional manager capability.
* Makefile.am: Don't generate host.cfg.in.
* Makefile.am, Makefile.inc.in, configure.ac, target.cfg.in: Update to
account for movement of .cfg files.
* Makefile.am: Use '|' as sed-delimiter.
PR 1760/misc
* compilers/gcc-target-default.cfg: Fix typo in CPP definition.
* Makefile.inc.in: Fix PROJECT_ROOT to match usage in templates and
existing Makefiles.
* Makefile.am, configure.ac: Move file generation into Makefile.
* Makefile.inc.in: Set PROJECT_ROOT = @pkgdatadir@.
* Makefile.am: Install *.cfgs into $(pkgdatadir)/make.
PR 1753/misc:
* host.cfg.in: Remove RTEMS_HOST.
PR 1754/misc:
* host.cfg.in: Remove GCCSED.
PR 1532/testing
* host.cfg.in: Add initial tests for untar capabilities. This required
BIN2C.
* Makefile.inc.in, bsp.cfg.in, configure.ac, target.cfg.in:
Remove itron.
* aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove.
* bsp.mak: Remove RTEMS_BSP_FAMILY.
* configure.ac: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS.
* aclocal/enable-bare.m4: Remove (Abandoned).
* bsp.cfg.in: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS.
* configure.ac: Remove RTEMS_ENABLE_BARE.
