path: root/c/src/make/lib.cfg (follow)
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-1/+1
| | | | | | | * lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg * main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP). * host.cfg.in: Remove RM, make-script. * ChangeLog: Remove bogus 2001-01-22 entry.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-1/+1
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-2/+0
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-201-0/+20
