Close #3250.
Close #4081.
PR 1589/build
* leaf.cfg, target.cfg.in, compilers/gcc-target-default.cfg: Remove
obsolete optional manager capability.
* leaf.cfg: Remove hard-coded .exe.
* leaf.cfg, compilers/gcc-target-default.cfg, custom/default.cfg.in:
Eliminate START_BASE and START_FILE.
* leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in
make-exe and make-cxx-exe definitions. This was resulting in the
linker script being processed twice and breaking some BSPs.
* leaf.cfg, compilers/gcc-target-default.cfg: Remove use of AM_LDFLAGS.
Ensure LDFLAGS works all the time. Clean up BSPs which defined their
own make-exe rules inappropriately.
* leaf.cfg: Do not override bsp-post-link.
* leaf.cfg: Switch to explicit .exe instead of EXEEXT to get it to
work. Primarily move the executable transformation rules to leaf.cfg.
* leaf.cfg: Add optional manager stub for Barrier.
* leaf.cfg: Remove Depends inclusion.
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
rtems-rc-4.5.0-7.diff. This file is being added to the main branch
in hopes that it will be easier to deal with the full merge later.
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
host programs are now compiled with automake generated rules. This was
done after discussions with Ralf Corsepius and Eric Norum.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
<corsepiu@faw.uni-ulm.de>.
it work.
<raguet@crf.canon.fr> to make their patches work together.
valid cpp symbol.
