path: root/c/src/make/directory.cfg (follow)
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-04-161-45/+12
| | | | | | | | | | | | | | | | FYI: I am not talking about using "make -C <dir>", which probably is much faster on M$ hosts than RTEMS's implementation, but about removing --enable-gmake-print support and to apply a variant of automake's subdirectory. Automake's subdirectory rule seems to be a little bit faster, but I wouldn't bet on this. Attached to this mail is my proposal. After applying the patch, please run cvs rm aclocal/enable-gmake-print.m4 ./autogen
* Improved missing directory message.Joel Sherrill1998-09-241-1/+4
* Added test so the build procedure would stop if a directory did not exist.Joel Sherrill1998-04-031-0/+2
| | | | | This typically indicates a bug in a directory level Makefile or a configure scrip bug.
* Fix from Chris Johns for inconsistent invocation of make.Joel Sherrill1998-03-161-1/+1
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-1/+10
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-201-0/+43
