* leaf.cfg, compilers/gcc-target-default.cfg, custom/default.cfg.in:
Eliminate START_BASE and START_FILE.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
that does some cleanup:
* remove c/src/make/main.cfg.in (obsolete, unused) and any reference to it.
* remove RTEMS_BSP_SPECS from c/src/make/custom/default.cfg.in (unused)
All files being effected by this patch are only used when building
RTEMS, therefore this patch should not have any side-effects outside
of the source- rsp. build-tree.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
