* Makefile.inc.in, bsp.cfg.in, configure.ac, target.cfg.in:
Remove itron.
* aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove.
* bsp.cfg.in: Hard-code HAS_RDBG = no.
* target.cfg.in: Hard-code RTEMS_HAS_RDBG = no.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
for RTEMS.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
