* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+4 |
| | | | | * configure.in: Reworked for autoconf-2.52. | ||||
* | 2001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-02-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Use exec_prefix not prefix. | ||||
* | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-02-05 | 1 | -0/+6 |
| | | | | | | * Makefile.inc.in: Add exec_prefix, remove terminating / from PROJECT_ROOT. * host.cfg.in: Update from <toplevel>/make/host.cfg.in | ||||
* | 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-02-02 | 1 | -0/+4 |
| | | | | * Makefile.inc.in: Remove RTEMS_HOST. | ||||
* | 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-15 | 1 | -0/+4 |
| | | | | * Makefile.inc.in: Use * instead of *_FOR_TARGET (BUG-FIX). | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -0/+4 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-31 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to GNU canonicalized autoconf macros. | ||||
* | 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-13 | 1 | -0/+4 |
| | | | | * leaf.cfg: Remove Depends inclusion. | ||||
* | 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-12 | 1 | -0/+6 |
| | | | | | | * leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE, LINKCMDS handling. * default.cfg.in: Remove everything but START_BASE. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
