* configure.ac: Remove RTEMS_PATH_PERL (Unused).
* aclocal/check-itron.m4: New.
* aclocal/enable-inlines.m4: New.
* Makefile.am: Add -I aclocal to ACLOCAL_AMFLAGS.
* bsp.mak: Remove support for profile-variant.
* configure.ac: Ditto.
* directory.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* make/README: Remove references to profile-variant.
* bsp.mak: Use ac_cv_env instead of ac_cv for cached vars.
* target.cfg.in: New, copy of c/make/target.cfg.in.
* configure.ac: Add target.cfg.
* Makefile.am: Add target.cfg.
* Makefile.am: Don't include @RTEMS_BSP@.cfg (unused).
* compilers/gcc-target-default.cfg: Make build variants work
for user applications.
* Makefile.inc.in: Remove RTEMS_USE_GCC272, RTEMS_LIBC_DIR.
* compilers/gcc-target-default.cfg: Remove obsolete reference to
src/libxil/Makefile.
Comment out LD_PATHS from LDFLAGS (Now implicitly handled by gcc
-spec).
* compilers/gcc-target-default.cfg: Add -qrtems-debug handling.
* configure.ac: Only symlink leaf.cfg.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* lib.cfg: Ditto.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.inc.in: Comment out RTEMS_USE_GCC272.
Comment out RTEMS_LIBC_DIR.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
* bsp.mak: New.
* Makefile.am: Remove RTEMS_BSP.cache generation.
Remove handling custom/*.cfgs.
Remove handling custom/default.cfg.
* configure.ac: Remove handling of custom/*.cfgs.
Remove auto* generated custom/default.cfg.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* configure.in: Reworked for autoconf-2.52.
* Makefile.am: Use exec_prefix not prefix.
* Makefile.inc.in: Add exec_prefix, remove terminating / from
PROJECT_ROOT.
* host.cfg.in: Update from <toplevel>/make/host.cfg.in
* Makefile.inc.in: Remove RTEMS_HOST.
* Makefile.inc.in: Use * instead of *_FOR_TARGET (BUG-FIX).
* Makefile.am: Switch to GNU canonicalized autoconf macros.
* leaf.cfg: Remove Depends inclusion.
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
