* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 18 | -39/+0 |
* | librtems++ - Remove junk line accidentally committed | Joel Sherrill | 2012-05-11 | 1 | -3/+2 |
* | librtems++ - Disable Interrupt Class When Not Simple Vectored | Joel Sherrill | 2012-05-09 | 1 | -0/+4 |
| | | | | | | This class only works on Simple Vectored Architectures. Even worse, it is not guaranteed to compile on a Programmable Interrupt Vector architecture. | ||||
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 2 | -0/+6 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -14/+0 |
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2009-12-22 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-12-22 | 3 | -2/+7 |
| | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h: Fixed timeout calculation. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | White space removal. | Ralf Corsepius | 2009-11-28 | 6 | -11/+11 |
* | 2009-11-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-23 | 1 | -0/+6 |
| | | | | | | * src/rtemsInterrupt.cc: #include <cstdlib>. * src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc, src/rtemsTask.cc, src/rtemsTimer.cc: #include <cstring>. | ||||
* | #include <cstring>. | Ralf Corsepius | 2009-11-23 | 4 | -4/+4 |
* | #include <cstdlib>. | Ralf Corsepius | 2009-11-23 | 1 | -1/+1 |
* | 2009-11-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-23 | 2 | -1/+10 |
| | | | | * configure.ac: Check for cstdlib, cstring. | ||||
* | 2009-08-06 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-08-06 | 2 | -2/+13 |
| | | | | | * src/rtemsInterrupt.cc: Fixed the code to compile on targets with CPU_SIMPLE_VECTORED_INTERRUPTS defined to true. | ||||
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 6 | -6/+13 |
| | | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsTimer.h, src/rtemsTask.cc: Eliminate all public use of TOD conversion routines. | ||||
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 2 | -6/+11 |
| | | | | | * include/rtems++/rtemsTimer.h: Use public API not _TOD_Microseconds_per_tick. | ||||
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 5 | -9/+16 |
| | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, src/rtemsTask.cc: Use public API not _TOD_Microseconds_per_tick. | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * include/rtems++/rtemsTaskMode.h: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 1 | -6/+6 |
* | 2008-08-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-04 | 2 | -3/+8 |
| | | | | | PR 1282/misc * src/rtemsInterrupt.cc: Correct vec/vector variable confusion. | ||||
* | 2007-02-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-02-06 | 3 | -12/+17 |
| | | | | | * include/rtems++/rtemsMessageQueue.h, src/rtemsMessageQueue.cc: Make compile by using size_t and uint32_t where appropriate. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | 2006-12-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-12-13 | 8 | -54/+54 |
| | | | | | | | | | | * librtems++/include/rtems++/rtemsEvent.h, librtems++/include/rtems++/rtemsMessageQueue.h, librtems++/include/rtems++/rtemsSemaphore.h, librtems++/include/rtems++/rtemsTask.h, librtems++/src/rtemsEvent.cc, librtems++/src/rtemsMessageQueue.cc, librtems++/src/rtemsSemaphore.cc, librtems++/src/rtemsTask.cc: Change rtems_unsigned32 to uint32_t. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-09-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-09-13 | 2 | -4/+5 |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -1/+5 |
| | | | | * src/rtemsStatusCode.cc: Fix warnings. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -7/+7 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | New. | Ralf Corsepius | 2005-08-15 | 1 | -0/+63 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -0/+6 |
| | | | | | | * Makefile.am: Add preinstall.am. * configure.ac: Add AMPOLISH3. * preinstall.am: New. | ||||
* | Add AMPOLISH3. | Ralf Corsepius | 2005-08-15 | 1 | -0/+4 |
* | Add preinstall.am. | Ralf Corsepius | 2005-08-15 | 1 | -54/+3 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -1/+5 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 2 | -16/+10 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-16 | 8 | -72/+72 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 6 | -27/+0 |
* | Unused. | Ralf Corsepius | 2004-03-08 | 3 | -6/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 2 | -1/+5 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 2 | -1/+5 |
| | | | | * Makefile.am: Preinstall dirs. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include lib.am. | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+7 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-15 | 3 | -12/+21 |
| | | | | | * configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS * Makefile.am: Use automake-compilation rules. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+11 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. |
