* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 6 | -6/+13 |
| | | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsTimer.h, src/rtemsTask.cc: Eliminate all public use of TOD conversion routines. | ||||
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 2 | -6/+11 |
| | | | | | * include/rtems++/rtemsTimer.h: Use public API not _TOD_Microseconds_per_tick. | ||||
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 5 | -9/+16 |
| | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, src/rtemsTask.cc: Use public API not _TOD_Microseconds_per_tick. | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * include/rtems++/rtemsTaskMode.h: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 1 | -6/+6 |
* | 2008-08-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-04 | 2 | -3/+8 |
| | | | | | PR 1282/misc * src/rtemsInterrupt.cc: Correct vec/vector variable confusion. | ||||
* | 2007-02-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-02-06 | 3 | -12/+17 |
| | | | | | * include/rtems++/rtemsMessageQueue.h, src/rtemsMessageQueue.cc: Make compile by using size_t and uint32_t where appropriate. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | 2006-12-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-12-13 | 8 | -54/+54 |
| | | | | | | | | | | * librtems++/include/rtems++/rtemsEvent.h, librtems++/include/rtems++/rtemsMessageQueue.h, librtems++/include/rtems++/rtemsSemaphore.h, librtems++/include/rtems++/rtemsTask.h, librtems++/src/rtemsEvent.cc, librtems++/src/rtemsMessageQueue.cc, librtems++/src/rtemsSemaphore.cc, librtems++/src/rtemsTask.cc: Change rtems_unsigned32 to uint32_t. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-09-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-09-13 | 2 | -4/+5 |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -1/+5 |
| | | | | * src/rtemsStatusCode.cc: Fix warnings. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -7/+7 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | New. | Ralf Corsepius | 2005-08-15 | 1 | -0/+63 |
* | 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-08-15 | 1 | -0/+6 |
| | | | | | | * Makefile.am: Add preinstall.am. * configure.ac: Add AMPOLISH3. * preinstall.am: New. | ||||
* | Add AMPOLISH3. | Ralf Corsepius | 2005-08-15 | 1 | -0/+4 |
* | Add preinstall.am. | Ralf Corsepius | 2005-08-15 | 1 | -54/+3 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -1/+5 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 2 | -16/+10 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-16 | 8 | -72/+72 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 6 | -27/+0 |
* | Unused. | Ralf Corsepius | 2004-03-08 | 3 | -6/+0 |
* | 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-20 | 2 | -1/+5 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 2 | -1/+5 |
| | | | | * Makefile.am: Preinstall dirs. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include lib.am. | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+7 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-15 | 3 | -12/+21 |
| | | | | | * configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS * Makefile.am: Use automake-compilation rules. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+11 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-13 | 2 | -6/+10 |
| | | | | * Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+9 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 2 | -30/+61 |
| | | | | * Makefile.am: Add dirstamp support. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 16 | -15/+26 |
| | | | | | | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h, include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h, include/rtems++/rtemsTimer.h, src/rtemsEvent.cc, src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc, src/rtemsTimer.cc: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -3/+7 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 3 | -2/+9 |
* | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-19 | 3 | -9/+14 |
| | | | | | | | * Makefile.am: Eliminate *_O_FILES. Use install-data-local instead of bsplist_DATA. * configure.ac: Require autoconf-2.57/automake-1.7.2. Apply 4th arg to AC_INIT to prevent autoconf to corrupt package name. | ||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-10 | 5 | -68/+56 |
| | | | | | | | | * src/Makefile.am: Remove. * include/Makefile.am: Remove. * Makefile.am: Merge-in src/Makefile.am, include/Makefile.am. * configure.ac: Reflect changes above. Unconditionally check for CXX. |
