* Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h,
include/rtems++/rtemsMessageQueue.h,
include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h,
include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h,
include/rtems++/rtemsTimer.h, src/rtemsEvent.cc,
src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc,
src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc,
src/rtemsTimer.cc: URL for license changed.
* Makefile.am: Eliminate *_O_FILES.
Use install-data-local instead of bsplist_DATA.
* configure.ac: Require autoconf-2.57/automake-1.7.2.
Apply 4th arg to AC_INIT to prevent autoconf to corrupt package name.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in src/Makefile.am, include/Makefile.am.
Unconditionally check for CXX.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/Makefile.am: Add bsplib_DATA. Eliminate LIBNAME. Cosmetical
changes.
* include/rtems++/Makefile.am: Remove.
* configure.in: Remove.
* include/rtems++/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems++/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
* src/rtemsInterrupt.cc: Allocated interrupt_table since since
cannot be determined without CPU model information.
* src/Makefile.am: Include compile.am
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
c/src/lib/librtems++ and c/src/lib/include/rtems++ to
their own package librtems++ at the top of the tree.
mkdir c/src/librtems++
cp c/src/lib/librtems++/README c/src/librtems++
mkdir c/src/librtems++/src
cp c/src/lib/librtems++/*.cc c/src/librtems++/src
cp c/src/lib/librtems++/Makefile.in c/src/librtems++/src
mkdir c/src/librtems++/include
mkdir c/src/librtems++/include/rtems++
cp c/src/lib/include/rtems++/*.h c/src/librtems++/include/rtems++
patch -p1 <rtems-rc-19990802-5.diff
rm -rf c/src/lib/librtems++
rm -rf c/src/lib/include/rtems++
Attention:
* The procedure above copies the files first, then patches them
and finally removes the old files afterwards. This has been done
to enable you to copy the files in CVS to preserve their history.
in the compiler not in the header file.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
