path: root/c/src/librtems++ (follow)
* 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-051-0/+4
| | | | * include/rtems++/rtemsTaskMode.h: Convert to "bool".
* Convert to "bool".Ralf Corsepius2008-09-051-6/+6
* 2008-08-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-08-042-3/+8
| | | | | PR 1282/misc * src/rtemsInterrupt.cc: Correct vec/vector variable confusion.
* 2007-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-02-063-12/+17
| | | | | * include/rtems++/rtemsMessageQueue.h, src/rtemsMessageQueue.cc: Make compile by using size_t and uint32_t where appropriate.
* Regenerate.Ralf Corsepius2007-01-081-2/+2
* 2006-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-12-138-54/+54
| | | | | | | | | | * librtems++/include/rtems++/rtemsEvent.h, librtems++/include/rtems++/rtemsMessageQueue.h, librtems++/include/rtems++/rtemsSemaphore.h, librtems++/include/rtems++/rtemsTask.h, librtems++/src/rtemsEvent.cc, librtems++/src/rtemsMessageQueue.cc, librtems++/src/rtemsSemaphore.cc, librtems++/src/rtemsTask.cc: Change rtems_unsigned32 to uint32_t.
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-022-1/+5
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-172-2/+6
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* 2006-09-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-09-132-4/+5
| | | | * configure.ac: Use RTEMS_AMPOLISH3.
* 2006-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-02-082-1/+5
| | | | * src/rtemsStatusCode.cc: Fix warnings.
* Regenerate.Ralf Corsepius2006-01-141-1/+1
* Regenerate.Ralf Corsepius2006-01-121-0/+4
* Remove all-local:.Ralf Corsepius2006-01-121-2/+0
* Regenerate.Ralf Corsepius2006-01-121-7/+7
* Cleanup.Ralf Corsepius2006-01-121-4/+0
* New.Ralf Corsepius2005-08-151-0/+63
* 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-08-151-0/+6
| | | | | | * Makefile.am: Add preinstall.am. * configure.ac: Add AMPOLISH3. * preinstall.am: New.
* Add AMPOLISH3.Ralf Corsepius2005-08-151-0/+4
* Add preinstall.am.Ralf Corsepius2005-08-151-54/+3
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-072-1/+5
| | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-062-16/+10
| | | | * Makefile.am: Remove build-variant support.
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-242-1/+5
| | | | * configure.ac: Require automake > 1.9.
* Remove stray white spaces.Ralf Corsepius2004-04-168-72/+72
* Remove stray white spaces.Ralf Corsepius2004-04-156-27/+0
* Unused.Ralf Corsepius2004-03-083-6/+0
* 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-202-1/+5
| | | | * Makefile.am: Cosmetics.
* 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-192-1/+5
| | | | * Makefile.am: Preinstall dirs.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-1/+4
| | | | * Makefile.am: Don't include lib.am.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-212-1/+7
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-153-12/+21
| | | | | * configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS * Makefile.am: Use automake-compilation rules.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+11
| | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-132-6/+10
| | | | * Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+9
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-30/+61
| | | | * Makefile.am: Add dirstamp support.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-022-1/+5
| | | | * Makefile.am: Remove all-local: $(ARCH).
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-222-1/+4
| | | | * configure.ac: Remove RTEMS_CANONICAL_HOST.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-212-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_CPU.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0416-15/+26
| | | | | | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h, include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h, include/rtems++/rtemsTimer.h, src/rtemsEvent.cc, src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc, src/rtemsTimer.cc: URL for license changed.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-182-1/+5
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-1/+1
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-162-3/+7
| | | | Makefile.am: Reflect having moved automake.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-113-2/+9
* 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-193-9/+14
| | | | | | | * Makefile.am: Eliminate *_O_FILES. Use install-data-local instead of bsplist_DATA. * configure.ac: Require autoconf-2.57/automake-1.7.2. Apply 4th arg to AC_INIT to prevent autoconf to corrupt package name.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-105-68/+56
| | | | | | | | * src/Makefile.am: Remove. * include/Makefile.am: Remove. * Makefile.am: Merge-in src/Makefile.am, include/Makefile.am. * configure.ac: Reflect changes above. Unconditionally check for CXX.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-1/+5
| | | | * src/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-9/+14
| | | | | * src/Makefile.am: Add bsplib_DATA. Eliminate LIBNAME. Cosmetical changes.
