* Makefile.am: Cosmetics.
* Makefile.am: Preinstall dirs.
* Makefile.am: Don't include lib.am.
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS
* Makefile.am: Use automake-compilation rules.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add dirstamp support.
* Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h,
include/rtems++/rtemsMessageQueue.h,
include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h,
include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h,
include/rtems++/rtemsTimer.h, src/rtemsEvent.cc,
src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc,
src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc,
src/rtemsTimer.cc: URL for license changed.
* Makefile.am: Eliminate *_O_FILES.
Use install-data-local instead of bsplist_DATA.
* configure.ac: Require autoconf-2.57/automake-1.7.2.
Apply 4th arg to AC_INIT to prevent autoconf to corrupt package name.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in src/Makefile.am, include/Makefile.am.
Unconditionally check for CXX.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/Makefile.am: Add bsplib_DATA. Eliminate LIBNAME. Cosmetical
changes.
* include/rtems++/Makefile.am: Remove.
* configure.in: Remove.
* include/rtems++/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems++/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
* src/rtemsInterrupt.cc: Allocated interrupt_table since since
cannot be determined without CPU model information.
* src/Makefile.am: Include compile.am
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
