* include/rtems++/Makefile.am: Remove.
* include/rtems++/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems++/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
