path: root/c/src/librtems++/include (follow)
* cpukit: deprecate notepadsGedare Bloom2015-03-101-2/+2
| | | | | | | | | | | | | | | Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-218-8/+8
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-118-16/+0
* 2009-12-22 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-12-222-2/+2
| | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h: Fixed timeout calculation.
* White space removal.Ralf Corsepius2009-11-286-11/+11
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-164-5/+5
| | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsTimer.h, src/rtemsTask.cc: Eliminate all public use of TOD conversion routines.
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-161-6/+6
| | | | | * include/rtems++/rtemsTimer.h: Use public API not _TOD_Microseconds_per_tick.
* 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-163-7/+8
| | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, src/rtemsTask.cc: Use public API not _TOD_Microseconds_per_tick.
* Convert to "bool".Ralf Corsepius2008-09-051-6/+6
* 2007-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-02-061-10/+10
| | | | | * include/rtems++/rtemsMessageQueue.h, src/rtemsMessageQueue.cc: Make compile by using size_t and uint32_t where appropriate.
* 2006-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-12-134-34/+34
| | | | | | | | | | * librtems++/include/rtems++/rtemsEvent.h, librtems++/include/rtems++/rtemsMessageQueue.h, librtems++/include/rtems++/rtemsSemaphore.h, librtems++/include/rtems++/rtemsTask.h, librtems++/src/rtemsEvent.cc, librtems++/src/rtemsMessageQueue.cc, librtems++/src/rtemsSemaphore.cc, librtems++/src/rtemsTask.cc: Change rtems_unsigned32 to uint32_t.
* Remove stray white spaces.Ralf Corsepius2004-04-168-72/+72
* Remove stray white spaces.Ralf Corsepius2004-04-156-27/+0
* Unused.Ralf Corsepius2004-03-082-4/+0
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-048-8/+8
| | | | | | | | | | | * include/rtems++/rtemsEvent.h, include/rtems++/rtemsInterrupt.h, include/rtems++/rtemsMessageQueue.h, include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsStatusCode.h, include/rtems++/rtemsTask.h, include/rtems++/rtemsTaskMode.h, include/rtems++/rtemsTimer.h, src/rtemsEvent.cc, src/rtemsInterrupt.cc, src/rtemsMessageQueue.cc, src/rtemsSemaphore.cc, src/rtemsStatusCode.cc, src/rtemsTask.cc, src/rtemsTimer.cc: URL for license changed.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-101-27/+0
| | | | | | | | * src/Makefile.am: Remove. * include/Makefile.am: Remove. * Makefile.am: Merge-in src/Makefile.am, include/Makefile.am. * configure.ac: Reflect changes above. Unconditionally check for CXX.
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-162-26/+21
| | | | | | | * include/rtems++/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * configure.ac: Reflect changes above. * Makefile.am: Require automake-1.5.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-1/+1
| | | | * include/rtems++/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-4/+3
| | | | | * include/rtems++/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-8/+5
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-132-0/+4
| | | | adds .cvsignore.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-042-612/+0
* Regenerated.Joel Sherrill1999-10-042-10/+12
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-074-0/+647
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-1/+1
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-318-0/+1136
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
