path: root/c/src/librpc/src/rpc/svc_tcp.c (unfollow)
2002-06-252002-06-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-481/+0
* Per PR233, moved librpc to exec. Ralf will patch after move. The patches associated with this PR are out of date. ./include/rpc/.cvsignore, ./include/rpc/Makefile.am, ./include/rpc/auth.h, ./include/rpc/auth_des.h, ./include/rpc/auth_unix.h, ./include/rpc/clnt.h, ./include/rpc/des.h, ./include/rpc/des_crypt.h, ./include/rpc/pmap_clnt.h, ./include/rpc/pmap_prot.h, ./include/rpc/pmap_rmt.h, ./include/rpc/rpc.h, ./include/rpc/rpc_com.h, ./include/rpc/rpc_msg.h, ./include/rpc/svc.h, ./include/rpc/svc_auth.h, ./include/rpc/types.h, ./include/rpc/xdr.h, ./include/.cvsignore, ./include/Makefile.am, ./include/rpcsvc/.cvsignore, ./include/rpcsvc/Makefile.am, ./include/rpcsvc/bootparam_prot.x, ./include/rpcsvc/crypt.x, ./include/rpcsvc/key_prot.x, ./include/rpcsvc/klm_prot.x, ./include/rpcsvc/mount.x, ./include/rpcsvc/nfs_prot.x, ./include/rpcsvc/nis.x, ./include/rpcsvc/nis_cache.x, ./include/rpcsvc/nis_callback.x, ./include/rpcsvc/nis_db.h, ./include/rpcsvc/nis_object.x, ./include/rpcsvc/nis_tags.h, ./include/rpcsvc/nislib.h, ./include/rpcsvc/nlm_prot.x, ./include/rpcsvc/pmap_prot.x, ./include/rpcsvc/rex.x, ./include/rpcsvc/rnusers.x, ./include/rpcsvc/rquota.x, ./include/rpcsvc/rstat.x, ./include/rpcsvc/rwall.x, ./include/rpcsvc/sm_inter.x, ./include/rpcsvc/spray.x, ./include/rpcsvc/yp.x, ./include/rpcsvc/yp_prot.h, ./include/rpcsvc/ypclnt.h, ./include/rpcsvc/yppasswd.x, ./include/rpcsvc/ypupdate_prot.x, ./include/rpcsvc/ypxfrd.x, ./.cvsignore, ./Makefile.am, ./README_RTEMS, ./configure.ac, ./src/rpc/PSD.doc/.cvsignore, ./src/rpc/PSD.doc/Makefile.am, ./src/rpc/PSD.doc/nfs.rfc.ms, ./src/rpc/PSD.doc/rpc.prog.ms, ./src/rpc/PSD.doc/rpc.rfc.ms, ./src/rpc/PSD.doc/rpcgen.ms, ./src/rpc/PSD.doc/xdr.nts.ms, ./src/rpc/PSD.doc/xdr.rfc.ms, ./src/rpc/.cvsignore, ./src/rpc/DISCLAIMER, ./src/rpc/Makefile.am, ./src/rpc/README, ./src/rpc/auth_des.c, ./src/rpc/auth_none.c, ./src/rpc/auth_time.c, ./src/rpc/auth_unix.c, ./src/rpc/authdes_prot.c, ./src/rpc/authunix_prot.c, ./src/rpc/bindresvport.3, ./src/rpc/bindresvport.c, ./src/rpc/clnt_generic.c, ./src/rpc/clnt_perror.c, ./src/rpc/clnt_raw.c, ./src/rpc/clnt_simple.c, ./src/rpc/clnt_tcp.c, ./src/rpc/clnt_udp.c, ./src/rpc/clnt_unix.c, ./src/rpc/crypt_client.c, ./src/rpc/des_crypt.3, ./src/rpc/des_crypt.c, ./src/rpc/des_soft.c, ./src/rpc/get_myaddress.c, ./src/rpc/getpublickey.c, ./src/rpc/getrpcent.3, ./src/rpc/getrpcent.c, ./src/rpc/getrpcport.3, ./src/rpc/getrpcport.c, ./src/rpc/key_call.c, ./src/rpc/key_prot_xdr.c, ./src/rpc/netname.c, ./src/rpc/netnamer.c, ./src/rpc/pmap_clnt.c, ./src/rpc/pmap_getmaps.c, ./src/rpc/pmap_getport.c, ./src/rpc/pmap_prot.c, ./src/rpc/pmap_prot2.c, ./src/rpc/pmap_rmt.c, ./src/rpc/publickey.3, ./src/rpc/publickey.5, ./src/rpc/rpc.3, ./src/rpc/rpc.5, ./src/rpc/rpc_callmsg.c, ./src/rpc/rpc_commondata.c, ./src/rpc/rpc_dtablesize.c, ./src/rpc/rpc_prot.c, ./src/rpc/rpc_secure.3, ./src/rpc/rpcdname.c, ./src/rpc/rstat.1, ./src/rpc/rstat_svc.8, ./src/rpc/rtems_portmapper.c, ./src/rpc/rtems_rpc.c, ./src/rpc/rtime.3, ./src/rpc/rtime.c, ./src/rpc/svc.c, ./src/rpc/svc_auth.c, ./src/rpc/svc_auth_des.c, ./src/rpc/svc_auth_unix.c, ./src/rpc/svc_raw.c, ./src/rpc/svc_run.c, ./src/rpc/svc_simple.c, ./src/rpc/svc_tcp.c, ./src/rpc/svc_udp.c, ./src/rpc/svc_unix.c, ./src/xdr/.cvsignore, ./src/xdr/Makefile.am, ./src/xdr/xdr.3, ./src/xdr/xdr.c, ./src/xdr/xdr_array.c, ./src/xdr/xdr_float.c, ./src/xdr/xdr_mem.c, ./src/xdr/xdr_rec.c, ./src/xdr/xdr_reference.c, ./src/xdr/xdr_sizeof.c, ./src/xdr/xdr_stdio.c, ./src/.cvsignore, ./src/Makefile.am: Moved to exec.
2000-10-312000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-7/+7
* POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c, src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c, src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c, src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c, src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix.
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-0/+481
2000-04-29New files added as part of librpc upgrade.Joel Sherrill1-0/+0
2000-04-28New files added on 4.5 branch.Joel Sherrill1-0/+0
1999-11-17New shell of a test for ITRON Mailbox Manager.Joel Sherrill1-0/+0
1999-11-10Combination of committing some new files which had been overlookedJoel Sherrill1-0/+0
and adding code which installed screens for itron tests.
