2002-06-25 | 2002-06-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 50 | -8701/+0 | |
* Per PR233, moved librpc to exec. Ralf will patch after move. The patches associated with this PR are out of date. ./include/rpc/.cvsignore, ./include/rpc/Makefile.am, ./include/rpc/auth.h, ./include/rpc/auth_des.h, ./include/rpc/auth_unix.h, ./include/rpc/clnt.h, ./include/rpc/des.h, ./include/rpc/des_crypt.h, ./include/rpc/pmap_clnt.h, ./include/rpc/pmap_prot.h, ./include/rpc/pmap_rmt.h, ./include/rpc/rpc.h, ./include/rpc/rpc_com.h, ./include/rpc/rpc_msg.h, ./include/rpc/svc.h, ./include/rpc/svc_auth.h, ./include/rpc/types.h, ./include/rpc/xdr.h, ./include/.cvsignore, ./include/Makefile.am, ./include/rpcsvc/.cvsignore, ./include/rpcsvc/Makefile.am, ./include/rpcsvc/bootparam_prot.x, ./include/rpcsvc/crypt.x, ./include/rpcsvc/key_prot.x, ./include/rpcsvc/klm_prot.x, ./include/rpcsvc/mount.x, ./include/rpcsvc/nfs_prot.x, ./include/rpcsvc/nis.x, ./include/rpcsvc/nis_cache.x, ./include/rpcsvc/nis_callback.x, ./include/rpcsvc/nis_db.h, ./include/rpcsvc/nis_object.x, ./include/rpcsvc/nis_tags.h, ./include/rpcsvc/nislib.h, ./include/rpcsvc/nlm_prot.x, ./include/rpcsvc/pmap_prot.x, ./include/rpcsvc/rex.x, ./include/rpcsvc/rnusers.x, ./include/rpcsvc/rquota.x, ./include/rpcsvc/rstat.x, ./include/rpcsvc/rwall.x, ./include/rpcsvc/sm_inter.x, ./include/rpcsvc/spray.x, ./include/rpcsvc/yp.x, ./include/rpcsvc/yp_prot.h, ./include/rpcsvc/ypclnt.h, ./include/rpcsvc/yppasswd.x, ./include/rpcsvc/ypupdate_prot.x, ./include/rpcsvc/ypxfrd.x, ./.cvsignore, ./Makefile.am, ./README_RTEMS, ./configure.ac, ./src/rpc/PSD.doc/.cvsignore, ./src/rpc/PSD.doc/Makefile.am, ./src/rpc/PSD.doc/nfs.rfc.ms, ./src/rpc/PSD.doc/rpc.prog.ms, ./src/rpc/PSD.doc/rpc.rfc.ms, ./src/rpc/PSD.doc/rpcgen.ms, ./src/rpc/PSD.doc/xdr.nts.ms, ./src/rpc/PSD.doc/xdr.rfc.ms, ./src/rpc/.cvsignore, ./src/rpc/DISCLAIMER, ./src/rpc/Makefile.am, ./src/rpc/README, ./src/rpc/auth_des.c, ./src/rpc/auth_none.c, ./src/rpc/auth_time.c, ./src/rpc/auth_unix.c, ./src/rpc/authdes_prot.c, ./src/rpc/authunix_prot.c, ./src/rpc/bindresvport.3, ./src/rpc/bindresvport.c, ./src/rpc/clnt_generic.c, ./src/rpc/clnt_perror.c, ./src/rpc/clnt_raw.c, ./src/rpc/clnt_simple.c, ./src/rpc/clnt_tcp.c, ./src/rpc/clnt_udp.c, ./src/rpc/clnt_unix.c, ./src/rpc/crypt_client.c, ./src/rpc/des_crypt.3, ./src/rpc/des_crypt.c, ./src/rpc/des_soft.c, ./src/rpc/get_myaddress.c, ./src/rpc/getpublickey.c, ./src/rpc/getrpcent.3, ./src/rpc/getrpcent.c, ./src/rpc/getrpcport.3, ./src/rpc/getrpcport.c, ./src/rpc/key_call.c, ./src/rpc/key_prot_xdr.c, ./src/rpc/netname.c, ./src/rpc/netnamer.c, ./src/rpc/pmap_clnt.c, ./src/rpc/pmap_getmaps.c, ./src/rpc/pmap_getport.c, ./src/rpc/pmap_prot.c, ./src/rpc/pmap_prot2.c, ./src/rpc/pmap_rmt.c, ./src/rpc/publickey.3, ./src/rpc/publickey.5, ./src/rpc/rpc.3, ./src/rpc/rpc.5, ./src/rpc/rpc_callmsg.c, ./src/rpc/rpc_commondata.c, ./src/rpc/rpc_dtablesize.c, ./src/rpc/rpc_prot.c, ./src/rpc/rpc_secure.3, ./src/rpc/rpcdname.c, ./src/rpc/rstat.1, ./src/rpc/rstat_svc.8, ./src/rpc/rtems_portmapper.c, ./src/rpc/rtems_rpc.c, ./src/rpc/rtime.3, ./src/rpc/rtime.c, ./src/rpc/svc.c, ./src/rpc/svc_auth.c, ./src/rpc/svc_auth_des.c, ./src/rpc/svc_auth_unix.c, ./src/rpc/svc_raw.c, ./src/rpc/svc_run.c, ./src/rpc/svc_simple.c, ./src/rpc/svc_tcp.c, ./src/rpc/svc_udp.c, ./src/rpc/svc_unix.c, ./src/xdr/.cvsignore, ./src/xdr/Makefile.am, ./src/xdr/xdr.3, ./src/xdr/xdr.c, ./src/xdr/xdr_array.c, ./src/xdr/xdr_float.c, ./src/xdr/xdr_mem.c, ./src/xdr/xdr_rec.c, ./src/xdr/xdr_reference.c, ./src/xdr/xdr_sizeof.c, ./src/xdr/xdr_stdio.c, ./src/.cvsignore, ./src/Makefile.am: Moved to exec. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -3/+0 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-09-28 | 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='. | |||||
2001-02-05 | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -2/+5 | |
* include/rpc/Makefile.am: Apply include_*HEADERS instead of H_FILES. | |||||
2000-06-29 | Corrected prototype for xdrrec_endofrecord to match C body. | Joel Sherrill | 1 | -1/+1 | |
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 48 | -310/+7502 | |
2000-05-01 | Added on 4.5-branch | Joel Sherrill | 2 | -0/+0 | |
2000-04-29 | New files added as part of librpc upgrade. | Joel Sherrill | 13 | -0/+0 | |
2000-04-29 | New directory added as part of librpc upgrade. | Joel Sherrill | 23 | -0/+0 | |
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2 | -0/+4 | |
adds .cvsignore. | |||||
1999-11-23 | Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -2/+2 | |
that are part of the Makefile.am conversion effort but were missed in the previous commits. | |||||
1999-11-22 | Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -6/+6 | |
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams. | |||||
1999-10-04 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1 | -3/+3 | |
where wrapup left pieces out of the librtemsall.a. | |||||
1999-10-04 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -0/+10 | |
The patch below actuallly consists of two patches: 1) moving librpc to c/src/librpc similar to what has been done to librtems++ 2) reworked configure scripts, many safety and dependency checks added to aclocal/*.m4 macros + configuration fixes. To apply: mkdir c/src/librpc mkdir c/src/librpc/src cp c/src/lib/librpc/*.c c/src/librpc/src cp c/src/lib/librpc/Makefile.in c/src/librpc/src mkdir c/src/librpc/include mkdir c/src/librpc/include/rpc cp c/src/lib/include/rpc/* c/src/librpc/include/rpc patch -p1 < ../rtems-rc-19990820-7.diff rm -rf c/src/lib/librpc rm -rf c/src/lib/include/rpc ./autogen The additional checks in aclocal/*m4 macros add rather restrictive, sometimes unnecessarily restrictive constraints on the sequence of how macros can be used in a configure.in script. Adding them has let my problems with some more complicated configuration options vanish. Apparently some macros had not been in the required order . ---- Now I still get some linking errors for some cpus and bsps, esp when linking cdtest, but also at other locations: e.g. this happens for mips64orion/p4600: # make[5]: Entering directory `/lfs/poseidon/users/rtems/src/multi/build/mips64orion-rtems/c/p4600/tests/samples/hello' /opt/rtems/bin/mips64orion-rtems-gcc --pipe -B../../../../../../p4600/lib/ -specs bsp_specs -qrtems -DP4000 -DCPU_R4000 -DP3_DIAG -D_R4000 -D__mips=3 -mcpu=4600 -G0 -I../../../../../../p4600/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -o o-p4600/hello.exe o-p4600/init.o ../../../../../../p4600/lib/no-dpmem.rel ../../../../../../p4600/lib/no-event.rel ../../../../../../p4600/lib/no-msg.rel ../../../../../../p4600/lib/no-mp.rel ../../../../../../p4600/lib/no-part.rel ../../../../../../p4600/lib/no-signal.rel ../../../../../../p4600/lib/no-timer.rel ../../../../../../p4600/lib/no-rtmon.rel /opt/rtems/mips64orion-rtems/lib/libc.a(dtoa.o): In function `_dtoa_r': /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol collect2: ld returned 1 exit status # mips64orion-rtems-gcc -v Reading specs from /opt/rtems/lib/gcc-lib/mips64orion-rtems/2.95.1/specs gcc version 2.95.1 19990816 (release) # mips64orion-rtems-ld -v GNU ld version 2.9.5 (with BFD 2.9.5) | |||||
1999-09-07 | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1 | -0/+26 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | |||||
1998-12-03 | Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add remote debug server | Joel Sherrill | 8 | -0/+1469 | |
and RPC support to RTEMS. Thanks. :) Email follows: Hello, For Xmas, here is the Remote Debugger on RTEMS ! Here are 2 patches for the Remote Debugger on RTEMS for pc386 from Linux host : - one for RTEMS it self, - one for GDB-4.17. 1/ RTEMS patch -------------- This patch adds 2 libraries : - a simplified SUN RPC library - the Remote Debugger library The configuration command is the following : ../rtems4/configure --target=i386-rtemself --enable-rtemsbsp=pc386 --enable-rdbg The SUN RPC library is built only if networking is set. The RDBG library is built if networking and enable-rdbg are set. The function used to initialize the debugger is : rtems_rdbg_initialize (); A special function has been created to force a task to be in a "debug" state : enterRdbg(). The use of this function is not mandatory. 2/ GDB-4.17 patch ----------------- This patch create a new RTEMS target for GDB-4.17. The configuration command is the following : ./configure --enable-shared --target=i386RTEMS To connect to a target, use : target rtems [your_site_address] Then, attach the target using : attach 1 And... Debug ;) You can obtain the original GDB-4.17 on ftp://ftp.debian.org/debian/dists/stable/main/source/devel/gdb_4.17.orig.tar.gz This has been tested from a Debian 2.0.1 linux host. |
