* src/i386/any/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/m68k/any/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/powerpc/new_exception_processing/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/_servtgt.c, src/ptrace.c: Corrected use of
_Objects_Information_table now that it is a two dimensional
array based upon API and class.
* src/i386/any/remdeb_svc.c, src/m68k/any/remdeb_svc.c,
src/powerpc/new_exception_processing/remdeb_svc.c: Readding as
I accidentally deleted the incorrectly empty versions.
* src/m68k/rdbg_cpu_asm.S: Per PR163, Fix incorrect assumption that
exception stack frames on M68K members with VBR always are 6 byte long.
The incorrect assumption resulted in some gdb commands like "next"
to fail on the 68360.
src/powerpc/new_exception_processing/remdeb_svc.c: Per PR220 remove
these files from CVS.
* src/powerpc/rdbg_f.c: Always include <rtems.h> instead of
internal include files.
* src/powerpc/rdbg_cpu_asm.S: Reflect changes to
<rtems/score/cpu.h>.
* src/powerpc/rdbg_f.c: Ditto.
* include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
PR 149
* src/i386/any/Makefile.am: s/$(SED)/sed/.
* src/m68k/any/Makefile.am: s/$(SED)/sed/.
* src/powerpc/new_exception_processing/Makefile.am: s/$(SED)/sed/.
(Reported by Till Straumann <strauman@SLAC.Stanford.EDU>)
* So many patches have been posted recently on the mailing list and
because we were unable to find correct solution to compile on various
linux distros (due to rpcgen incompatibilities), and because the coding
style of rdbg was rather inconsistant among various pieces of code, I
decided to:
1) make some cleaning regarding global coding style (using
indent + manual edits),
2) incorporate/review the paches send by various people
(S. Holford, T. Strauman),
3) Fix the bug due to varying rpcgen code generation
in remdeb_svc.c,
4) Remove some dead code,
5) Apply a patches enabling to call enterRdbg imediately
after rdbg initialization is done,
NB : the paches is huge but it is mainly due to coding styke chnages.
Only few lines of codes have been really changed and they do not impact
rdbg functionnality (AFAIKT).
* include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h,
include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h,
src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c,
src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c,
src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c,
src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h,
src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c,
src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am,
src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c,
src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c,
src/powerpc/new_exception_processing/Makefile.am,
src/powerpc/new_exception_processing/remdeb.h,
src/powerpc/new_exception_processing/remdeb_svc.c,
src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
decided to:
in remdeb_svc.c,
* src/powerpc/excep_f.c: This patch addresses the following issues:
- exception handler needs to enable MSR_FP if the interrupted
thread is FP enabled.
- printk message for MSR fixed and added stacktrace
NOTE: this requires the stacktrace patch to
lib/libbsp/powerpc/shared/vectors/vector_init.c
(#ifdef DDEBUG only, however)
* src/powerpc/new_exception_processing/remdeb_svc.c: Corrected
macro using variable arguments.
* src/powerpc/new_exception_processing/remdeb.h,
src/powerpc/new_exception_processing/remdeb_xdr.c: Regenerated since
I updated the main RTEMS development machine to RedHat 7.2 and
apparently got a new version of rpcgen.
* src/m68k/rdbg_cpu_asm.S: Now compiles on ColdFire.
* include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/i386/any/Makefile.am: Move MAINTAINERCLEANFILES before the
includes and use MAINTAINERCLEANFILES = to make automake-1.5 happy.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
* include/rdbg/rdbg.h, src/ptrace.c: Modifications to make gcc 3.x happy.
* mcp750 directory renamed new_exception processing as it
supports many more CPU models.
* configure.in, src/powerpc/Makefile.am,
src/powerpc/new_exception_processing/remdeb_f.x: New files
formerly in mcp750 plus modifications.
* src/powerpc/mcp750/.cvsignore, src/powerpc/mcp750/Makefile.am,
src/powerpc/mcp750/remdeb.h, src/powerpc/mcp750/remdeb_f.x,
src/powerpc/mcp750/remdeb_svc.c, src/powerpc/mcp750/remdeb_xdr.c:
Removed when moved to new_exception_processing.
src/powerpc/new_exception_processing/remdeb_f.x: Modified as
part of this effort to add support for the MPC8xx.
* src/m68k/any/remdeb.h, src/m68k/any/remdeb_xdr.c,
src/m68k/any/remdeb_svc.c: New files missed in merger.
* configure.in: Add m68k support.
* include/rdbg/m68k, src/m68k, src/m68k/any: New subdirectory.
* src/_servtgt.c: add status text to prinf upon task creation failure.
* src/rdbg.c: reconnect rdbg exception handlers upon RPC calls.
* src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/m68k/any/remdeb_f.x, src/m68k/any/.cvsignore,
src/m68k/any/remdeb_svc.c, src/m68k/excep_f.c, src/m68k/rdbg_cpu_asm.S,
src/m68k/rdbg_f.c, src/m68k/.cvsignore: New files.
* src/i386/any/Makefile.am, src/powerpc/mcp750/Makefile.am: Include
compile.am
with the new RPC code.
that contains:
* Removes MKLIB
handling)
converted to automake.
that addresses the librdbg/rpcgen related problems:
* All rpcgen generated files are now kept inside of the source tree
* Fix librdbg/configure to correctly detect presence of rpcgen and awk
* Use rpcgen -m to generated remdeb_svc.c
* Remove msgout/_msgout from awk.svc
* minor cleanups to librdbg/configure.in
ATTENTION --- IMPORTANT:
* With keeping rpc-generated files pre-build inside of the source tree,
you as the packager of RTEMS have to ensure that timestamps are
correctly set up: The generated files must not be older than the *.x
files.
* This is extraordinarily important when
- putting the package on read-only media
- after checking out from CVS
- after modifications to the *.x files
* If one of the *.x files is modified you have to either
- build for i386/pc386 and powerpc/mcp750
- or to invoke the same rpcgen calls as the
librdbg/src/<cpu>/<bsp>/Makefile.am do manually
before checking-in the files to CVS.
Proposal:
We could add something to bootstrap for touching the rpcgen-generated
sources and/or to manually regenerate them.
NOTE FROM JOEL:
Ralf proposed modifying bootstrap to handle rpcgen. I think this
is the best solution as it is something already done in the
snapshot procedure.
patch from Emmanuel Raguet <raguet@crf.canon.fr>. Emmanuel's patch
was against the Makefile.in's generated from the Makefile.am's
patched in this file.
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
to correct the missing part of the mcp750 patch.
which makes i386 code available for all BSPs not just pc386. This is correct
since the code is really general to all i386 BSPs now.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
reference to the Makefile.
done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
to its own top level package.
fixes related to GDB over TCP/IP debug.
