2001-04-20 | 2001-04-20 Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 1 | -928/+0 | |
* mcp750 directory renamed new_exception processing as it supports many more CPU models. * configure.in, src/powerpc/Makefile.am, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb_f.x: New files formerly in mcp750 plus modifications. * src/powerpc/mcp750/.cvsignore, src/powerpc/mcp750/Makefile.am, src/powerpc/mcp750/remdeb.h, src/powerpc/mcp750/remdeb_f.x, src/powerpc/mcp750/remdeb_svc.c, src/powerpc/mcp750/remdeb_xdr.c: Removed when moved to new_exception_processing. * configure.in, src/powerpc/Makefile.am, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb_f.x: Modified as part of this effort to add support for the MPC8xx. | |||||
2000-01-13 | Patch rtems-rc-20000104-17.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+928 | |
that addresses the librdbg/rpcgen related problems: Changes: * All rpcgen generated files are now kept inside of the source tree * Fix librdbg/configure to correctly detect presence of rpcgen and awk * Use rpcgen -m to generated remdeb_svc.c * Remove msgout/_msgout from awk.svc * minor cleanups to librdbg/configure.in ATTENTION --- IMPORTANT: * With keeping rpc-generated files pre-build inside of the source tree, you as the packager of RTEMS have to ensure that timestamps are correctly set up: The generated files must not be older than the *.x files. * This is extraordinarily important when - putting the package on read-only media - after checking out from CVS - after modifications to the *.x files * If one of the *.x files is modified you have to either - build for i386/pc386 and powerpc/mcp750 - or to invoke the same rpcgen calls as the librdbg/src/<cpu>/<bsp>/Makefile.am do manually before checking-in the files to CVS. Proposal: We could add something to bootstrap for touching the rpcgen-generated sources and/or to manually regenerate them. NOTE FROM JOEL: Ralf proposed modifying bootstrap to handle rpcgen. I think this is the best solution as it is something already done in the snapshot procedure. |
