path: root/c/src/librdbg/src/i386/any/remdeb.h (follow)
* 2002-02-01 Eric Valette <valette@crf.canon.fr>Joel Sherrill2002-02-011-492/+445
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * So many patches have been posted recently on the mailing list and because we were unable to find correct solution to compile on various linux distros (due to rpcgen incompatibilities), and because the coding style of rdbg was rather inconsistant among various pieces of code, I decided to: 1) make some cleaning regarding global coding style (using indent + manual edits), 2) incorporate/review the paches send by various people (S. Holford, T. Strauman), 3) Fix the bug due to varying rpcgen code generation in remdeb_svc.c, 4) Remove some dead code, 5) Apply a patches enabling to call enterRdbg imediately after rdbg initialization is done, NB : the paches is huge but it is mainly due to coding styke chnages. Only few lines of codes have been really changed and they do not impact rdbg functionnality (AFAIKT). * include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h, include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h, src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c, src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c, src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c, src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h, src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c, src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am, src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c, src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb.h, src/powerpc/new_exception_processing/remdeb_svc.c, src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
* * So many patches have been posted recently on the mailing list andJoel Sherrill2002-02-011-454/+464
* Patch rtems-rc-20000104-17.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-131-0/+559
that addresses the librdbg/rpcgen related problems: Changes: * All rpcgen generated files are now kept inside of the source tree * Fix librdbg/configure to correctly detect presence of rpcgen and awk * Use rpcgen -m to generated remdeb_svc.c * Remove msgout/_msgout from awk.svc * minor cleanups to librdbg/configure.in ATTENTION --- IMPORTANT: * With keeping rpc-generated files pre-build inside of the source tree, you as the packager of RTEMS have to ensure that timestamps are correctly set up: The generated files must not be older than the *.x files. * This is extraordinarily important when - putting the package on read-only media - after checking out from CVS - after modifications to the *.x files * If one of the *.x files is modified you have to either - build for i386/pc386 and powerpc/mcp750 - or to invoke the same rpcgen calls as the librdbg/src/<cpu>/<bsp>/Makefile.am do manually before checking-in the files to CVS. Proposal: We could add something to bootstrap for touching the rpcgen-generated sources and/or to manually regenerate them. NOTE FROM JOEL: Ralf proposed modifying bootstrap to handle rpcgen. I think this is the best solution as it is something already done in the snapshot procedure.
