path: root/c/src/librdbg/include/rdbg/powerpc/Makefile.am (unfollow)
2004-02-132004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-30/+0
* librdbg/include/Makefile.am: Merge-in librdbg/include/rdbg/i386/Makefile.am, librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am, librdbg/include/rdbg/powerpc/Makefile.am. * librdbg/include/rdbg/i386/Makefile.am, librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am, librdbg/include/rdbg/powerpc/Makefile.am: Remove. * configure.ac: Reflect changes above.
2004-01-212004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+3
* include/rdbg/Makefile.am: Add PREINSTALL_DIRS. * include/rdbg/i386/Makefile.am: Add PREINSTALL_DIRS. * include/rdbg/m68k/Makefile.am: Add PREINSTALL_DIRS. * include/rdbg/powerpc/Makefile.am: Add PREINSTALL_DIRS. * src/i386/Makefile.am: Add PREINSTALL_DIRS. * src/m68k/Makefile.am: Add PREINSTALL_DIRS. * src/powerpc/Makefile.am: Add PREINSTALL_DIRS.
2004-01-142004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+3
* include/rdbg/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * include/rdbg/i386/Makefile.am: Ditto. * include/rdbg/m68k/Makefile.am: Ditto. * include/rdbg/powerpc/Makefile.am: Ditto. * src/i386/Makefile.am: Ditto. * src/m68k/Makefile.am: Ditto. * src/powerpc/Makefile.am: Ditto.
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-2/+1
* include/rdbg/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * include/rdbg/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * include/rdbg/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * include/rdbg/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * src/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * src/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * src/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
2003-12-012003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-8/+14
* Makefile.am: Reformat. Apply dirstamps to preinstallation. * include/Makefile.am: Ditto. * include/rdbg/Makefile.am: Ditto. * include/rdbg/i386/Makefile.am: Ditto. * include/rdbg/m68k/Makefile.am: Ditto. * include/rdbg/powerpc/Makefile.am: Ditto: * src/Makefile.am: Ditto. * src/i386/Makefile.am: Ditto. * src/i386/any/Makefile.am: Ditto. * src/m68k/Makefile.am: Ditto. * src/m68k/any/Makefile.am: Ditto. * src/powerpc/Makefile.am: Ditto. * src/powerpc/new_exception_processing/Makefile.am: Ditto.
2003-08-162003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. include/rdbg/Makefile.am: Reflect having moved automake. include/rdbg/i386/Makefile.am: Reflect having moved automake. include/rdbg/m68k/Makefile.am: Reflect having moved automake. include/rdbg/powerpc/Makefile.am: Reflect having moved automake. src/Makefile.am: Reflect having moved automake. src/i386/Makefile.am: Reflect having moved automake. src/i386/any/Makefile.am: Reflect having moved automake. src/m68k/Makefile.am: Reflect having moved automake. src/m68k/any/Makefile.am: Reflect having moved automake. src/powerpc/Makefile.am: Reflect having moved automake. src/powerpc/new_exception_processing/Makefile.am: Reflect having moved automake.
2003-07-252003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* configure.ac: Remove (Merged into ../configure.ac). * Makefile.am, include/Makefile.am, include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am, src/Makefile.am, src/i386/Makefile.am, src/i386/any/Makefile.am, src/m68k/Makefile.am, src/m68k/any/Makefile.am, src/powerpc/Makefile.am, src/powerpc/new_exception_processing/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-09-272001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='. * src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='. * src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='. * src/powerpc/new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-02-122001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-12/+3
* include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am: Cleanup including more proper style on include files.
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-6/+3
1999-11-22Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-7/+7
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams.
1999-10-04Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1-3/+3
1999-09-07Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1-0/+33
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
