* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* include/rdbg/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/i386/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/m68k/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/powerpc/Makefile.am: Add PREINSTALL_DIRS.
* src/i386/Makefile.am: Add PREINSTALL_DIRS.
* src/m68k/Makefile.am: Add PREINSTALL_DIRS.
* src/powerpc/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Ditto.
* include/rdbg/m68k/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto.
* src/i386/Makefile.am: Ditto.
* src/m68k/Makefile.am: Ditto.
* src/powerpc/Makefile.am: Ditto.
* include/rdbg/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* include/Makefile.am: Ditto.
* include/rdbg/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto:
* src/Makefile.am: Ditto.
* src/i386/any/Makefile.am: Ditto.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
include/rdbg/Makefile.am: Reflect having moved automake.
include/rdbg/i386/Makefile.am: Reflect having moved automake.
include/rdbg/m68k/Makefile.am: Reflect having moved automake.
include/rdbg/powerpc/Makefile.am: Reflect having moved automake.
src/Makefile.am: Reflect having moved automake.
src/i386/Makefile.am: Reflect having moved automake.
src/i386/any/Makefile.am: Reflect having moved automake.
src/m68k/Makefile.am: Reflect having moved automake.
src/m68k/any/Makefile.am: Reflect having moved automake.
src/powerpc/Makefile.am: Reflect having moved automake.
src/powerpc/new_exception_processing/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, include/Makefile.am, include/rdbg/Makefile.am,
include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am,
include/rdbg/powerpc/Makefile.am, src/Makefile.am,
src/i386/Makefile.am, src/i386/any/Makefile.am,
src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/powerpc/Makefile.am,
* include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
because we were unable to find correct solution to compile on various
linux distros (due to rpcgen incompatibilities), and because the coding
style of rdbg was rather inconsistant among various pieces of code, I
decided to:
1) make some cleaning regarding global coding style (using
indent + manual edits),
2) incorporate/review the paches send by various people
(S. Holford, T. Strauman),
3) Fix the bug due to varying rpcgen code generation
in remdeb_svc.c,
4) Remove some dead code,
5) Apply a patches enabling to call enterRdbg imediately
after rdbg initialization is done,
NB : the paches is huge but it is mainly due to coding styke chnages.
Only few lines of codes have been really changed and they do not impact
rdbg functionnality (AFAIKT).
* include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h,
include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h,
src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c,
src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c,
src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c,
src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h,
src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c,
src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am,
src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c,
src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c,
src/powerpc/new_exception_processing/Makefile.am,
src/powerpc/new_exception_processing/remdeb.h,
src/powerpc/new_exception_processing/remdeb_svc.c,
src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
* include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/powerpc/new_exception_processing/Makefile.am: Use
* include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am,
include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am:
Cleanup including more proper style on include files.
* configure.in: Add m68k support.
* include/rdbg/m68k, src/m68k, src/m68k/any: New subdirectory.
* src/_servtgt.c: add status text to prinf upon task creation failure.
* src/rdbg.c: reconnect rdbg exception handlers upon RPC calls.
* src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/m68k/any/remdeb_f.x, src/m68k/any/.cvsignore,
src/m68k/any/remdeb.h, src/m68k/any/remdeb_xdr.c,
src/m68k/any/remdeb_svc.c, src/m68k/excep_f.c, src/m68k/rdbg_cpu_asm.S,
src/m68k/rdbg_f.c, src/m68k/.cvsignore: New files.
