* configure.ac, wrapup/Makefile.am: Remove RDBG.
* aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore,
librdbg/Makefile.am, librdbg/preinstall.am,
librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h,
librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h,
librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h,
librdbg/include/rdbg/powerpc/rdbg_f.h,
librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c,
librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c,
librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c,
librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c,
librdbg/src/servtsp.c, librdbg/src/servutil.c,
librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S,
librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h,
librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c,
librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c,
librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c,
librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x,
librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S,
librdbg/src/powerpc/rdbg_f.c,
librdbg/src/powerpc/new_exception_processing/remdeb.h,
librdbg/src/powerpc/new_exception_processing/remdeb_f.x,
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* include/rdbg/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/i386/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/m68k/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/powerpc/Makefile.am: Add PREINSTALL_DIRS.
* src/i386/Makefile.am: Add PREINSTALL_DIRS.
* src/m68k/Makefile.am: Add PREINSTALL_DIRS.
* src/powerpc/Makefile.am: Add PREINSTALL_DIRS.
* include/rdbg/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Ditto.
* include/rdbg/m68k/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto.
* src/i386/Makefile.am: Ditto.
* src/m68k/Makefile.am: Ditto.
* src/powerpc/Makefile.am: Ditto.
* include/rdbg/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* include/Makefile.am: Ditto.
* include/rdbg/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto:
* src/Makefile.am: Ditto.
* src/i386/any/Makefile.am: Ditto.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
include/rdbg/Makefile.am: Reflect having moved automake.
include/rdbg/i386/Makefile.am: Reflect having moved automake.
include/rdbg/m68k/Makefile.am: Reflect having moved automake.
include/rdbg/powerpc/Makefile.am: Reflect having moved automake.
src/Makefile.am: Reflect having moved automake.
src/i386/Makefile.am: Reflect having moved automake.
src/i386/any/Makefile.am: Reflect having moved automake.
src/m68k/Makefile.am: Reflect having moved automake.
src/m68k/any/Makefile.am: Reflect having moved automake.
src/powerpc/Makefile.am: Reflect having moved automake.
src/powerpc/new_exception_processing/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, include/Makefile.am, include/rdbg/Makefile.am,
include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am,
include/rdbg/powerpc/Makefile.am, src/Makefile.am,
src/i386/Makefile.am, src/i386/any/Makefile.am,
src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/powerpc/Makefile.am,
* include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
because we were unable to find correct solution to compile on various
linux distros (due to rpcgen incompatibilities), and because the coding
style of rdbg was rather inconsistant among various pieces of code, I
decided to:
1) make some cleaning regarding global coding style (using
indent + manual edits),
2) incorporate/review the paches send by various people
(S. Holford, T. Strauman),
3) Fix the bug due to varying rpcgen code generation
in remdeb_svc.c,
4) Remove some dead code,
5) Apply a patches enabling to call enterRdbg imediately
after rdbg initialization is done,
NB : the paches is huge but it is mainly due to coding styke chnages.
Only few lines of codes have been really changed and they do not impact
rdbg functionnality (AFAIKT).
* include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h,
include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h,
src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c,
src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c,
src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c,
src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h,
src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c,
src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am,
src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c,
src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c,
src/powerpc/new_exception_processing/Makefile.am,
src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
* include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/powerpc/new_exception_processing/Makefile.am: Use
* include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am,
include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am:
Cleanup including more proper style on include files.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
<raguet@crf.canon.fr>:
- the dec21140 driver code has been hardened (various bug fixed) Emmanuel,
- bug in the mcp750 init code have been fixed (interrupt stack/initial
stack initialization), BSS correctly cleared (Eric V)
- remote debugging over TCP/IP is nearly complete (berakpoints,
backtrace, variables,...) (Eric V),
- exception handling code has also been improved in order to fully
support RDBG requirements (Eric V),
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
