* include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am,
include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am:
Cleanup including more proper style on include files.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
