* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* src/powerpc/new_exception_processing/Makefile.am: Remove.
* src/powerpc/Makefile.am: Merge-in former
new_exception_processing/Makefile.am.
* src/m68k/any/Makefile.am: Remove.
* src/m68k/Makefile.am: Merge-in former any/Makefile.am.
* src/i386/any/Makefile.am: Remove.
* src/i386/Makefile.am: Merge-in former any/Makefile.am.
* src/Makefile.am: Cosmetics.
* include/Makefile.am: Cosmetics.
* Makefile.am: Cosmetics.
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* include/Makefile.am: Ditto.
* include/rdbg/Makefile.am: Ditto.
* include/rdbg/i386/Makefile.am: Ditto.
* include/rdbg/m68k/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto:
* src/Makefile.am: Ditto.
* src/i386/Makefile.am: Ditto.
* src/i386/any/Makefile.am: Ditto.
* src/m68k/Makefile.am: Ditto.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
include/rdbg/Makefile.am: Reflect having moved automake.
include/rdbg/i386/Makefile.am: Reflect having moved automake.
include/rdbg/m68k/Makefile.am: Reflect having moved automake.
include/rdbg/powerpc/Makefile.am: Reflect having moved automake.
src/Makefile.am: Reflect having moved automake.
src/i386/Makefile.am: Reflect having moved automake.
src/i386/any/Makefile.am: Reflect having moved automake.
src/m68k/Makefile.am: Reflect having moved automake.
src/m68k/any/Makefile.am: Reflect having moved automake.
src/powerpc/Makefile.am: Reflect having moved automake.
src/powerpc/new_exception_processing/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, include/Makefile.am, include/rdbg/Makefile.am,
include/rdbg/i386/Makefile.am, include/rdbg/m68k/Makefile.am,
include/rdbg/powerpc/Makefile.am, src/Makefile.am,
src/i386/Makefile.am, src/i386/any/Makefile.am,
src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/powerpc/Makefile.am,
* include/rdbg/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rdbg/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/i386/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/any/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/m68k/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/powerpc/new_exception_processing/Makefile.am: Remove AUTOMAKE_OPTIONS.
that contains:
* Removes MKLIB
handling)
done as part of a patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
problem.
