* src/powerpc/new_exception_processing/remdeb.h: Regenerated.
* src/powerpc/excep_f.c: This patch addresses the following issues:
- exception handler needs to enable MSR_FP if the interrupted
thread is FP enabled.
- printk message for MSR fixed and added stacktrace
NOTE: this requires the stacktrace patch to
lib/libbsp/powerpc/shared/vectors/vector_init.c
(#ifdef DDEBUG only, however)
* src/powerpc/new_exception_processing/remdeb_svc.c: Corrected
macro using variable arguments.
* src/powerpc/new_exception_processing/remdeb.h,
src/powerpc/new_exception_processing/remdeb_xdr.c: Regenerated since
I updated the main RTEMS development machine to RedHat 7.2 and
apparently got a new version of rpcgen.
* src/m68k/rdbg_cpu_asm.S: Now compiles on ColdFire.
* configure.ac: Fix latent bug exposed by removal of config.cache's
which prevented powerpc targets librdbg from building.
* configure.in: Remove.
* include/rdbg/i386/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/m68k/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/powerpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rdbg/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/i386/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/m68k/any/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/powerpc/new_exception_processing/Makefile.am: Use
* src/i386/any/Makefile.am: Move MAINTAINERCLEANFILES before the
includes and use MAINTAINERCLEANFILES = to make automake-1.5 happy.
* src/m68k/any/Makefile.am: Ditto.
* src/powerpc/new_exception_processing/Makefile.am: Ditto.
* include/rdbg/rdbg.h, src/ptrace.c: Modifications to make gcc 3.x happy.
* mcp750 directory renamed new_exception processing as it
supports many more CPU models.
* configure.in, src/powerpc/Makefile.am,
src/powerpc/new_exception_processing/Makefile.am,
src/powerpc/new_exception_processing/remdeb_f.x: New files
formerly in mcp750 plus modifications.
* src/powerpc/mcp750/.cvsignore, src/powerpc/mcp750/Makefile.am,
src/powerpc/mcp750/remdeb.h, src/powerpc/mcp750/remdeb_f.x,
src/powerpc/mcp750/remdeb_svc.c, src/powerpc/mcp750/remdeb_xdr.c:
Removed when moved to new_exception_processing.
src/powerpc/new_exception_processing/remdeb_f.x: Modified as
part of this effort to add support for the MPC8xx.
* include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am,
include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am:
Cleanup including more proper style on include files.
* src/m68k/any/remdeb.h, src/m68k/any/remdeb_xdr.c,
src/m68k/any/remdeb_svc.c: New files missed in merger.
* configure.in: Add m68k support.
* include/rdbg/m68k, src/m68k, src/m68k/any: New subdirectory.
* src/_servtgt.c: add status text to prinf upon task creation failure.
* src/rdbg.c: reconnect rdbg exception handlers upon RPC calls.
* src/m68k/Makefile.am, src/m68k/any/Makefile.am,
src/m68k/any/remdeb_f.x, src/m68k/any/.cvsignore,
src/m68k/any/remdeb_svc.c, src/m68k/excep_f.c, src/m68k/rdbg_cpu_asm.S,
src/m68k/rdbg_f.c, src/m68k/.cvsignore: New files.
* src/i386/any/Makefile.am, src/powerpc/mcp750/Makefile.am: Include
compile.am
